Breaking '98 Mastiff (yorkshire)
Postby gutsibikes » Fri Feb 08, 2008 2:24 pm
Due to a melted loom I'm breaking my 1998 Mastiff in the UK. I recently fitted a 12000 mile Yamaha XTZ motor (with mechanical tacho drive). As a guide to condition the bike was in 'well used' condition but none of the fasteners have been seized except for the exhaust studs on the original £95 engine. The Yamaha engine was in very good condition and had only been in the bike for one month. The following are available:
12000 mile XTZ660 motor with flywheel and pickups - £425
45000 mile bare XTZ motor - this is the original motor and has a gearbox fault where it falls out of 2nd and 4th gears - £95
seat (red) - £30
tank - burgandy colour - £35
black LH and RH side panels - £5 each
speedo showing about 28000 miles - £20
tacho - £20
rear monoshock - £25
swingarm - £20
front calliper - £15
rear calliper (missing anti rattle spring)- £10
frame with V5 (S reg) - £75
starter motor - £40
Most other parts are available except for forks and wheels. Email ed@wolfenstein.freeserve.co.uk. if you're looking for something that isn't listed here. Shipping will be extra, I'll ship anywhere in the UK.
gutsibikes
Re: Breaking '98 Mastiff (yorkshire)
Postby Garf » Fri Feb 08, 2008 3:44 pm
Sent you a PM mate.
HR Black Panther
Garf
Postby gutsibikes » Mon Feb 18, 2008 10:49 am
motor with bad gearbox, side panels and fork brace have now gone.
All other parts remaining including good 12000 mile XTZ motor
give me a shout if you fancy any bits this week, other wise it's all going on Fleabay!
I'm in Huddersfield, Yorkshire
gutsibikes
Postby MUZZIE » Wed May 07, 2008 4:42 pm
WHAT YOU GOT LEFT BUDDY ANYTHING?,MUZZIE :roll:
MUZZIE
Postby gutsibikes » Fri May 23, 2008 4:31 pm
Just posted the 17" wheels on Ebay UK -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=008
starting at £5!
also have the following left over and going cheap -
front mudguard
starter motor
fusebox
airbox
rear calliper and mount
clutch lever and clamp
gear lever
RH mirror
rear brake lever and rod
hand guards
front sprocket cover
throttle cables
fuel tank, cap and tap
handlebars
choke lever
gutsibikes
Postby gutsibikes » Mon May 26, 2008 4:18 am
looks like the wheels are going cheap - don't miss out if you're considering lowering your Baghira with 17" wheels
gutsibikes
Postby gutsibikes » Sat Jun 14, 2008 12:36 pm
just the following now remaining:
front mudguard
rear calliper mount (alloy fitting on wheel spindle)
handlebars
choke lever
gutsibikes
