F/S: Skorpion race bike bits
Re: F/S: Skorpion race bike bits
Postby hb7 » Sun Jul 29, 2012 11:29 am
What are you guys looking for.....? I have to reduce some.....
hb7777@gmail.com
hb7
Postby morbidelli17 » Wed Aug 08, 2012 8:56 am
Sill have the aluminum subframe for sale.
morbidelli17
Postby mforza » Wed Aug 08, 2012 4:13 pm
Did you sold the SV rear conversion? Sent you PM a while ago.
mforza
Postby morbidelli17 » Thu Aug 09, 2012 12:05 am
Hey guy. Yes, it was sold just before you PM'd me. As far as I know, all I've got left is an aluminum subframe, two radiator caps and a swingarm protector.
That's not true. I have very, very fond memories of racing an MZ, something I've always wanted to do, and feel privileged to be part of this community.
morbidelli17
Postby mforza » Fri Aug 10, 2012 10:32 am
Dang, was hoping to get it from you. That will save me some work :)
Can you tell me what exactly is needed to be done to make that conversion?
Thx Martin
mforza
Postby hb7 » Fri Aug 10, 2012 6:52 pm
I have some woodcraft rear sets on adapter plates for the Skorp....
hb7
Postby mforza » Fri Aug 10, 2012 7:52 pm
Thae only thing I need is the rear wheel conversion, that I can fit 160 tire on it. I'm using 160 right now on the MZ wheel but need wider rim to use the tire properly.
mforza
Postby morbidelli17 » Sat Aug 11, 2012 11:46 am
OK, all the hard bits are gone.
Rear wheel conversion: Two spacers. Recessed inner (sprocket side) bearing by 15mm. Took 15mm off of sprocket carrier. Cut and re-welded brake caliper holder. I wish I could tell you more, but I contracted the job out ... :)
Take care - M
morbidelli17
Postby mforza » Sat Aug 11, 2012 9:16 pm
Cool, that helps :)
I can't do it myself anyway so I let them deal with that in the shop :-D
mforza
Previous
