Baghira 50mm Adjustable Marzocchi magnum forks
PostPosted: Sat May 31, 2008 12:31 am
by hb7
Baghira 50mm Adjustable Marzocchi magnum forks with triple.
Forks are in good condition useable as is, no leaking seals, Stanchions are in good shape and straight.
Add oil, install and go ride.
Forks can be inspected for 5 days and returned if you want.
Adjustable cap on one side doesn't click but still turns.
This is completely normal, as it is the second time I have observed this on a Baghira. The problem is
only in the cap, not in the damper mechanism. The cap is a KTM part#...Btw.
$350 shipped in USA
Inquire here : hb7@ca.rr.com
http://home.roadrunner.com/~hb77/images/f1.JPG
http://home.roadrunner.com/~hb77/images/f2.JPG
http://home.roadrunner.com/~hb77/images/f3.JPG
http://home.roadrunner.com/~hb77/images/f4.JPG
http://home.roadrunner.com/~hb77/images/f5.JPG
http://home.roadrunner.com/~hb77/images/f6.JPG
http://home.roadrunner.com/~hb77/images/f7.JPG
http://home.roadrunner.com/~hb77/images/f8.JPG
http://home.roadrunner.com/~hb77/images/f9.JPG
