fuel pump assembly
fuel pump assembly
Postby tomtom » Sat Feb 13, 2010 10:39 am
tomtom
Re: fuel pump assembly
Postby LWS66 » Sat Feb 13, 2010 1:24 pm
Ive got an 07 TNT, I'll have to give it a look and see. But I'm not so sure sourcing anything from Benelli will be cost effective vs. getting it from MZ, or the aftermarket. Some on the Benelli forum are looking for alternative coils for instance and are looking outside of the Benelli sourced.....like the MZ ones which appear the same.
LWS66
Postby boilermaker » Sat Feb 13, 2010 2:00 pm
Tom
Who makes the fuel pump assembly?
boilermaker
Postby tomtom » Sat Feb 13, 2010 2:46 pm
tomtom
Postby tomtom » Sat Feb 13, 2010 2:48 pm
tomtom
Postby tomtom » Sat Feb 13, 2010 2:50 pm
tomtom
Postby tomtom » Sat Feb 13, 2010 2:51 pm
tomtom
Postby tomtom » Sat Feb 13, 2010 2:53 pm
picture of original fuel pump from the mz manual
i'll try and take some clear pics using a better quality camera and replace some of the fuzzy ones above.
tomtom
Postby meenamoo » Sat Oct 22, 2011 2:10 am
Hi,I have recently perchased a mz 1000s and for some reason the fuel pump doesn't run,I have tested the voltage with the ignition 'on' on the pump and the injectors and everything gets power but the pump won't run,I then took the pump out of the tank and put wires directly from the battery to the pump and it works but it has a screeming sound,could be because its not in the fuel,what could cause the pump not to run when its conected to all the other electonics,its a 2006 mz 1000s,please could anyone help,and if the pump has gone where could I find a replacement because the mz agents in south africa don't exist anymore,is the maybe another bikes pump I could use?
meenamoo
Postby LWS66 » Sat Oct 22, 2011 8:22 pm
Don't assume the worst case scenario, most likely it could be a fuse, or possibly the relay. Start with the simple, work towards the complicated. :-D
LWS66
Postby boilermaker » Sun Oct 23, 2011 11:16 am
Meenamoo
Try it in a bucket of water. Be aware that the screetching noise could be the pump running dry without the fuel as the lubricating medium.
boilermaker
Postby MJ310 » Thu Oct 27, 2011 9:34 am
Does the bike have an alarm/immobiliser on it. The fuel pump is one of the best places to put in the immobiliser relay into. Check this out first if you have one fitted.
Mick
MJ310
Return to 1000S
