TPS Issues
Posted:
Fri Apr 24, 2020 8:03 am
by d-lane
Hello, I got a 2005 MZ 1000s. Parts are extremely rear around here in the US. I finally got some of the parts I needed hand made and put on. Bike fired up a couple of times and ran awesome. Long story short, I cranked it the 2 days ago and the bike instantly jumped to 9k rpms while idling. I thought maybe the throttle cable was stuck, but after quick examination of it, nothing seems to be out of the ordinary. Only thing I can come up with is that I have a faulty TPS sensor. Has anyone on here found a site that still sells or makes parts for this bike?? Any help would be greatly appreciated!!!!
Re: TPS Issues
Posted:
Fri Apr 24, 2020 5:11 pm
by Thorsten-aus-SO
Hi.
Most parts are available in Germany.
Check out
https://www.muz.de/ or ask in the german forum
http://mz1000.motomonster.de/Ask in your language. No problem.
Re: TPS Issues
Posted:
Sat Apr 25, 2020 1:38 pm
by d-lane
awesome, thanks for your help!
Re: TPS Issues
Posted:
Tue Apr 28, 2020 11:58 pm
by silver MZ-1000s
Hi , did you scan the codes ? Are you sure it’s a TPS ? Did you check your low RPM air acuttator motor ? The one on your air filter box where two hoses from your throthle bodies come to , its on same side as your TPS sensor on the bottom of the air box . If it would be it it think 2nd gen aprilia got something simular , good luck .
Re: TPS Issues
Posted:
Wed Apr 29, 2020 12:04 am
by silver MZ-1000s
BTW , i don’t think TPS will cause your motor to rev that hi , check for air leaks , check your throthle body hoses .
