Page 1 of 2
Trans lockout?
Posted:
Mon Jun 06, 2011 12:00 pm
by Mach IV
Can't get it into gear,running or not clutch in or out.
I replaced the urine cup for the clutch master and bled it.
Re: Trans lockout?
Posted:
Tue Jun 07, 2011 3:21 pm
by boilermaker
Has the machine been standing for a long time ?
Re: Trans lockout?
Posted:
Tue Jun 07, 2011 4:52 pm
by iceman
viewtopic.php?f=2&t=3786Re: Can anyone identify what came out with my oil on my 1000s?
Postby LWS66 ยป Fri Oct 09, 2009 10:42 pm
Don't worry! That piece is the same piece I discovered way back when I first got my 1000 (new)and was out with the wife on a sunday, rolling through town changing gears when it hung up in gear. Could'nt get it into next gear. Tried up and down and just banged it hard into lower gear and all was fine. Worried me a bit, then at next oil change out poured the same exaxt piece as in your photo. If you check the parts manual you will see all the components of the trans/shifter. That little "tang" is part of the shifter internals connected to the shifter shaft and I believe is more of a "stop" of some sort, than anything else. Mine broke off at less than 1000 miles. Now at over 32000 miles and never any issues. Don't worry about it. Has been discussed on the German forum.
LWS66
Re: Trans lockout?
Posted:
Tue Jun 07, 2011 5:43 pm
by Mach IV
It's been sitting for over a year.
Re: Trans lockout?
Posted:
Wed Jun 08, 2011 1:34 pm
by boilermaker
Mach
I would look in to the possibility put forward by Iceman.. Get someone to rock the machine back and forth whilst you operate the gear selector pedal (engine off). The other possibilities are a broken gear actuator spring (not so bad as it sounds, actuator mechanism is outside the gearbox thank christ!) or a gummed together clutch, or just plain air in the system.
Re: Trans lockout?
Posted:
Wed Jun 08, 2011 7:34 pm
by Mach IV
Will the gummed up clutch or air in the line keep it from leaving nuetral?
Most Jap bikes I've owned will go into first not running even if the clutch isn't "working".
I tried the rocking thing,also removed the rod and gave it a few good yanks and it' remained in N.
Re: Trans lockout?
Posted:
Wed Jun 08, 2011 10:30 pm
by DAVID THOMPSON
here is the picture and what is see commented on
in the next post below
save and print both posts its easier to read that way
Re: Trans lockout?
Posted:
Wed Jun 08, 2011 10:50 pm
by DAVID THOMPSON
clip 30 can come loose spring 31 may break
spring 33 can break
a 1974 bmw has a spring almost the same as 31 that was known to break
and let a lever drop down and not shift
the pin wheel at 22 is similar to one in some other trans i have worked on
and it was what a lever worked against to make it shift if a spring in it broke it did not work
i think you have lost a spring at 31 33 or 26
the roller on item 25 may have came off
hope this helps i don,t think its more than bad springs
the one like # 33 i have replaced maybe a dozen times in mid 1970,s bmw 5 speeds
2 of them in my 1974 r90s # 33 may even be the same as the bmw spring
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 1:06 am
by boilermaker
mach
If the problem does lie with the spring that David is referring (and there is a very strong possibility that it does) to then you will find my previous posting (on this website) on the problem where the replacement sequence is outlined, including the manufacture of a special clutch drum removal tool. The spring itself can be purchased from Grahams here in UK. Be aware that the spring may not look broken but on dissasembly of the mechanism it will fall apart. You should also replace the clutch cover gasket following removal /replacing of the cover.
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 1:08 am
by boilermaker
Mach
Sorry, I should have told you its spring No 33 in the drawing that usually breaks.
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 9:14 am
by iceman
The line that spring 33 touches ,(that tab looks like the one that hangs up and breaks off) and comes out in the oil as has happened to two members.
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 11:58 am
by Mach IV
So I pull the right cover off and clutch out to get to something on the left side of the motor?
Sounds like lotsa fun,do I need tiny hands or the ability to build miniature ships in a bottle?
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 12:15 pm
by Mach IV
Isn't this a Rotax motor?
Would an Aprilia dealer have the parts?
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 12:36 pm
by DAVID THOMPSON
my understanding was this is an mz in house design like the 125cc motors
grahams in the uk
i do not have any for the bmw bikes any more used all of them.. so nothing to compare to yours
but they sure look the same in pictures
Re: Trans lockout?
Posted:
Thu Jun 09, 2011 2:26 pm
by iceman
Mach IV wrote:Isn't this a Rotax motor?
I have two Aprilia's and the motor's are Rotax but the MZ is made in-house.
http://www.motorcyclenews.com/MCN/biker ... --current/Engine
MCN rating rating is 4
Owners' rating rating is 4.5
You have to admire MZ for building a parallel twin and making a good `un. The 1000S's 999cc motor is punchy, not too vibey and makes adequate poke
