Check engine light,
Posted:
Tue Oct 04, 2011 4:25 pm
by Mach IV
tried the search but it ignored me so it looks pretty much useless.
Anyway,how do you reset it?
I disconnected the batt but that didn't work.
Re: Check engine light,
Posted:
Wed Oct 05, 2011 1:41 pm
by boilermaker
Mach
As you have not told us why your engine light is on or what "search" you carried out then its difficult to help you. If you have carried out some sort of repair and the light is still on then be aware that it can take up to an hour of running before the light resets. The alternative is to reset it with one of the inexpensive fault code readers available on the market.
Posted:
Wed Oct 05, 2011 5:10 pm
by iceman
Posted:
Wed Oct 05, 2011 6:52 pm
by Mach IV
I forgot to plug the airbox in after changing the plugs,hence the CEL being tripped.
So,if the problem was resolved it should reset?
Posted:
Wed Oct 05, 2011 6:54 pm
by Mach IV
The search was simply "check engine light" and all I got was the words were too common.
Funny,I would think that together they are not that common.
Posted:
Wed Oct 05, 2011 7:36 pm
by iceman
I used what Boilermaker wrote: fault code readers
Now go put 200 miles on it and it should go out.
Posted:
Thu Oct 06, 2011 7:59 am
by boilermaker
Mach
John (iceman) is correct it should go out within a couple of hundred miles. I have obtained a cheap fault code reader that I use to reset spurious fault indications it is the "Memoscan U480" unit and I obtained it via E-Bay for about £30. I cannot give you any more info as there are no manufacturers details either on the unit or in the hand book. Good luck.
Posted:
Sun Oct 09, 2011 9:12 am
by Mach IV
I may ride it to Daytona this weekend for Biketoberfest.
I'm only 75 miles from there,trying to keep my rides short till I know
the bugs are out of it from sitting so long.
