Front Brake Failure - Help!
Postby Nozz » Thu Sep 20, 2007 6:35 pm
The front brake on my Silver Star failed this morning and left me walking. I happen to have a used spare to try a quick road side repair, but wanted to ask for advice from the group. Symptom wise, I noticed a slight drag on the disc, felt the grip and first it was stiffer than normal, then a couple of minutes later I had no brake at all, then it just tightened up and I was stopping right quick! First question, does this seem like a failure at the master cylinder end or the caliper end? Secondly, what is the next step for repair, can this be rebuilt or will I need a new caliper. ( It is a Grimeca single piston style) Thanks in advance.
Jim
Nozz
stopped
Postby DAVID THOMPSON » Fri Sep 21, 2007 10:40 pm
the parts up on the handle let fluid bleed back after you release brake
sounds like problem is in master cylinder
i will look at my parts book and see if overhaul kit is listed
does yours have a square top or screw off round top where fluid is poured in to reservoir
on there round top cyl there is a spring in side
ar dave
ps check if hand lever has full return travel when released or pressure will not release
items 2 to 6 on page
if this is not your master cyl i can post other one
or if you have parts book its on page32
book 31.jpg (455.32 KiB) Viewed 3436 times
Postby phlat65 » Sat Sep 22, 2007 10:25 am
yeah, if you crack the line or bleeder at the caliper and the brake releases, then you have a problem in the master. if the brake is still stuck, then caliper. did you make any recent adjustments or repairs?
Postby Nozz » Sat Sep 22, 2007 1:38 pm
Thanks for the advice. It is a rectangular reservoir model and I have a spare from my other bike. They towed it so I have to track it down and repair on the spot tomorrow. I will post another reply once I get it back on the road.
-Jim
Nozz
Postby Nozz » Mon Oct 01, 2007 7:36 pm
We're back on the road again. Apparently the brake pads just wore down completely and overheated causing the brake to sieze up. I substituted my spare caliper, so now I wonder if there is a quick cross reference part number for new pads for this brake. Are these same brakes used on any other bikes? Thanks!
-jim
Nozz
fa18
Postby DAVID THOMPSON » Mon Oct 01, 2007 9:36 pm
ebc fa18
some bmw models 1981 on
parts unlimited # = 1721 0259 = sbs 506hf r
came out bigger than i wanted but here it is for all to see
what fa18 fits
ar dave
the ebc listing
Postby Nozz » Tue Oct 02, 2007 9:43 am
Thanks Dave, I will track down some pads. I may seek to rebuild the caliper so I wonder if there is a cross ref. for this as well??
Nozz
Users browsing this forum: Bing [Bot] and 5 guests
