For the battery charge indicator I am using this: http://www.signaldynamics.com/products/Modules/huvm.asp
Cheap insurance to prevent this.
95SaxonTour wrote:Don,
which wire are you fusing? The black one, right? You have the low
voltage light tapped into the same wire?
What would cause the reg/rec to go out like that? One could
use a universal reg/rec as long as it had the same wires coming
out the back in a pinch, right? Ryan
