Speed wobble ? HELP
Speed wobble ? HELP
Postby Noodles36 » Wed May 21, 2014 12:44 pm
Hello to one and all ,
I picked up a 1981 MZ250 Ts with a sidecar .
Got her starting and running for the first time today . Took it for a little spin up the road just to see how she would go , in first gear and just taking off " she goes into a speed wobble" as in the handles bars giggle left to right " the faster I went the more violent it got . I didn't oust my luck .
Would any one have any ideas / help , has it happened to any other MZ owners ? Would it have something to do with the side car ?
Any help welcome .
Noodles36
Re: Speed wobble ? HELP
Postby therealche » Wed May 21, 2014 4:15 pm
They all do that Sir! Usually you can accelerate through it but sometimes it can be nasty!. Does the bike have a steering damper? If so screw it down to make the steering stiffer. If not you need one! Probably worth checking the alignment of the sidecar
Where VS = 30-50mm
therealche
Postby therealche » Wed May 21, 2014 4:21 pm
therealche
Postby Noodles36 » Wed May 21, 2014 5:15 pm
Many thanks for al the info . I will check the above tomorrow .
Noodles36
Postby DAVID THOMPSON » Wed May 21, 2014 5:20 pm
check tyre pressure all 3 tyres
also jack up front end and check the fork neck bearings for excess play
and the rear swing arm and bearings
and do a good all over inspection
each setup is its own and 2 bikes set up the same will almost never ride the same...
and i never give out test rides
every time i have been at a rally and some one crashes a rig it is usually not his machine..
my advice is NO TEST RIDES
Postby Noodles36 » Thu May 22, 2014 5:00 am
Many thanks David ,
Just had a quick inspection on the bike and straight away I seen the steering damper is knackerd " as in no friction " it's seen better days , it will need to be replaced anyway ,,
Noodles36
Postby Cerberus73 » Thu May 22, 2014 7:38 am
and hey if you decide you don't like the chair.. id be willing to take it off your hands for suitable beer tokens :lol:
Cerberus73
Postby therealche » Sat May 24, 2014 6:30 pm
If the damper is all there all you need to do is replace the friction disc. Made one out of a large cutting disc many years ago. Tight? Me ??????
therealche
