Tachometer is spastic
Postby comanche91 » Tue Sep 07, 2010 5:03 pm
Was riding around today on the Silver Star and the tach started going squirrelly, usually sitting on the peg indicating 0-RPM but jumps up occasionally and indicates what looks like the correct RPM, then drops off again. Does not appear to be RPM sensitive. Any suggestions? Thanks
-Don
1-3/4 1995 Silver Stars
comanche91
Re: Tachometer is spastic
Postby comanche91 » Fri Sep 10, 2010 5:26 pm
Found the problem, and I suspect this applies to all MZ Rotax bikes w. CDI ignition. The tach derives it's input signal from the CDI box on my 95. MZ decided to use one of those crappy squeeze-on splice connectors to connect the tach signal wire to the CDI box tach output wire. The intermittent contact inside the splice connector was causing the spastic tach. These connectors suck for all applications, but especially on a vibrating motorcycle. It's in the battery box, a brown squeeze-type splice connector sitting in there like an afterthought. The fix is to solder in a decent male/female connector and insulate it with shrink tubing.
-Don
comanche91
Return to 500 cc
Users browsing this forum: No registered users and 52 guests
