valve clearances.... a how to
right gear needed
a 10mm spanner
a 11mm spanner
a set of feeler gauges (metric)
a spark plug spanner
a flat head screwdriver
and what ever tools you need to remove the tank
1. remove tank
2. unbolt the decompression lever bracket
3. with a 10mm spanner remove the rocker covers (2)
4. undo the spark plug (with the decomp lever gone, you need the plug out to turn the engine over by hand)
5. turn the engine to top dead center.. supposedly you can see a little white mark through the peep hole which indicates it there..
i can't
anyway its not really needed, if you use the kick starter turn the engine over and watch the cam and rockers move. the exhaust rocker will go down (indicating exhaust stroke) then the inlet rocker will go down (you guessed it.. inlet stroke) then its the compression stroke followed by the power stroke
you don't have to be super accurate with this basically somewhere between compression and expansion (power) where neither cam lobe is pushing on the rocker arm
(number 3 on pic below)
6. now we are going to set the clearances (i saay set, because its just as easy to straight out set them, as it is to check them) on cam over bucket over shim engines or cam over shim engines you have to check and record the clearances before you change the shims so you know what new shim to insert... but no need to worry about that with the super simple rotax lump
7. loosen your inlet tappets with a 11mm spanner .
with your 0.05mm feeler (or for you americans ... 0.05mm
its a metric lump and the way of the future
slip it between the tappet and the top of the valve stem,
8. with your spanner on the lock nut and your feeler in place, tighten the tappen with your flat head screw driver, untill it becomes tight, then back the screwdriver off a wee bit. the feel should be able to move but you should feel the resistance of the tappet.. you'll know what i mean when you do it
9. do the other tappet, and then move to the exhaust
10. the exhaust side, now this is where a debate could start, the manual states 0.05mm for both exhaust and inlet clearances, its not a misprint, thats what rotax recomends, but i still do the exhaust at 0.08mm simply for the fact there is more heat on the exhaust valves and therefore move valve expansion, so any where between 0.05mm and 0.1mm is fine,
if you ride your mz hard then i recommend 0.1mm if you ride it nicely then i recomend somewhere between
and thats it, set your exhaust clearances to what ever you decide, make sure all your lock nuts are tight, chuck the rocker covers back on, connect the decomp cable, and your good to go
have fun
a 10mm spanner
a 11mm spanner
1. remove tank
i can't
have fun
