E-start Balance shaft same as non-E-start?
Posted:
Sat Sep 21, 2013 7:52 am
by davegsm82
As per the title, are the shafts the same in the 2 engines?
Thanks, Dave.
Re: E-start Balance shaft same as non-E-start?
Posted:
Sat Sep 21, 2013 10:53 am
by DAVID THOMPSON
which bike i know what you got others do not
and i do not know the answer
rotax.net can probally tell you
Posted:
Fri Sep 27, 2013 3:55 pm
by davegsm82
I contacted Keith at AmericanDirtbike, he showed me the difference between the e-start and non-estart balance shafts.
Unfortunately mine is a non-estart type shaft, so I will have to disassemble and fit a different balance shaft. Not too much of a problem, clutch cover is already off since it's completely knackered.
I've already sourced the E-start type cover, just need the balance shaft, sprag gears and motor.
Dave.
