Silver Star gearing.
Posted:
Thu Feb 11, 2016 1:58 pm
by DrGonzo
I am going to replace my 18T engine sprocket with either a 16T or 15T. I know the 16T is a popular mod and I am leaning toward it, just wondering if anyone has tried the 15T sprocket and what the results were.
Thanks,
Brad
Re: Silver Star gearing.
Posted:
Thu Feb 11, 2016 10:59 pm
by DAVID THOMPSON
mine i changed from 18 to 17
and its still a bit tall
15 will ware fast and put a lot of pressure on the output shaft bearing
Posted:
Fri Feb 12, 2016 8:43 am
by DrGonzo
Good info. I will just go with the 16T.
Posted:
Tue Feb 16, 2016 10:18 pm
by DrGonzo
Turns out my silver star has a 17T sprocket just like my owners manual said. It should, so now I am back to wondering if a 16T will give me the acceleration I am looking for. Maybe it won't rain tomorrow and I can tell a lil
Bit about the powerband now that my tach is working.
Posted:
Wed Feb 17, 2016 9:19 am
by MZCountryRider
I put a 16t on my Silver Star and it made a big improvement over the 17t. I could go uphill into a headwind without losing speed even at full throttle. Acceleration was improved, gas mileage virtually unchanged. Revving a bit higher at highway speeds, but not by much.
Rear tire size will have an effect as well. The stock 110/80-18 size isn't widely available, so I used a 110/90-18. Taller sidewalls/larger circumference made the effective gearing a bit taller.
Posted:
Thu Feb 18, 2016 2:40 pm
by DrGonzo
Thanks, I am going to go with the 16.
Posted:
Thu Feb 18, 2016 6:23 pm
by DAVID THOMPSON
there are a few scooter rear tires in the 110/80x16 size but hard to find any dealers with them in stock
headenu has a k44 snow tex in europe but no one seem to have any in usa
Posted:
Fri Feb 19, 2016 3:39 pm
by DrGonzo
DAVID THOMPSON wrote:there are a few scooter rear tires in the 110/80x16 size but hard to find any dealers with them in stock
I was referring to a 16 Tooth Sprocket. I will be fitting some Bridgestone BT45s in 90/90-18 and 110/80-18.
Posted:
Fri Feb 19, 2016 5:04 pm
by DAVID THOMPSON
mine is the saxon tour 500 and has a 16 inch REAR which is hard to find
