finding skorpion parts
Postby stonewally » Thu Nov 06, 2008 4:40 pm
Hello MZriders (first post here). It is time to make a serious attempt at making a cross-reference list of replacement parts for our bikes! Here is a start: While putting together a semi-basket case Skorpion sport model this past summer, a replacement (adjustable) brake lever for a Honda trx 400 quad was matched up from the rack at a local Cycle Gear store... Direct fit. Let's find all the parts that fit, and share that knowledge here, it is a shock to see that a bike with such a cult following, and many devotesd sites, has no such list. Lets do it now, share your hard won cross-reference research results and maybe MZ/MuzRiders will devote a heading for these lists... For all the MZ bikes.
stonewally
Re: finding skorpion parts
Postby Linegeist » Fri Nov 07, 2008 5:38 am
A great idea, however I suspect somebody might have got there before you over in the Mechanic/Tech Talk section - a couple of years ago.
viewtopic.php?f=20&t=606
Why not consider adding your new finds to that one? :wink:
Linegeist
Postby stonewally » Fri Nov 07, 2008 2:15 pm
Hey linegeist, I don't want to sound like a wiseguy, but... Yeah, right! Try finding these parts in the U.S., and wait 'til you start breaking parts on your latest bike there. When you search for related info on this site, it seems you get alot of replies to any given subject, and they lead off in any and all directions. One poor rider was asking for ideas on a replacement tail light lens for a Skorpion Sport model, and he gets several replies with information related to all models but the Sport, and alot of opinions in favor of switching to aftermarket units... That might be the best idea in that case, but lets build an actual list of what-fits-what for each model, stock, cross-referenced, improved replacements, and aftermarket... With part numbers and sources, no unrelated stories of mechanical genius or heroic riding, start a new post if you want to tell a story. This has got to be the best site going for MZ owners, lets make it more useful.
stonewally
Postby OLDMTNCARVER » Fri Nov 07, 2008 3:29 pm
Just a thought...
Might be helpful at first to start with individual threads related to only the specific part (general item) that is to be considered for replacement pieces for repair or total replacement of the part.
Thread examples might be something along these lines
Baghira: Fork parts
First post might be, Replacement seals with the related number
Next post might be, Replacement springs...
Baghira Fork replacement (Unit replacement)
First post might be, Yamaha 2003 YZ USD (Spacer needed to set race out for head to lower triple clearance...)
Spacer size: .190 thick / 1.625 ID / 1.980 OD (race OD)
Bearing numbers / Race numbers...other necessary comments on the installation.
Skorpion: Fork parts
Skorpion: Fork replacement
Yamaha R6...(another example)
Maybe use the parts book/manual as a guide.
Each member could start their own data base
Just a thought,
OMC
OLDMTNCARVER
