Baggy wiring problem for digital speedo (Koso DB01R)
Re: Baggy wiring problem for digital speedo (Koso DB01R)
Postby Chalks » Thu Jan 10, 2013 1:56 pm
Not quite finished mounting it yet, even though I've never seen it light up I need to wire in a temperature warning light. It appears to operate from the same 3 pin sensor as the radiator fan (which I've never heard running until I bridged it today either). :( I f*+#king hate anything with wires coming out of it, being colour blind adds to my fury! I'll post a pic at the weekend when it's finished.
Chalks
Postby duncmac » Thu Jan 10, 2013 4:59 pm
Sounds like a ball ache, esp the colour blindness bit.
Looking forward to the pics :-D :-D
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby Chalks » Sat Jan 12, 2013 12:36 pm
Mission accomplished! Ball ache is not even close! I've probably gone a bit OTT on the wiring and soldering the joints (it's a pitty MZ didn't think like this when they built it) but if you're going to a job you might aswell do it properly, I don't recon much to the KOSO mounting brackets for the display panel or the pick up sensor so I've grafted some of my own.
Chalks
Postby duncmac » Sat Jan 12, 2013 4:30 pm
Looks nice, does it allow you to monitor/measure the rpms???
Dont be shy show us the rest of the bike!!
duncmac
Postby Chalks » Sun Jan 13, 2013 6:05 am
Yep, the bars on the top rise and fall with the RPM, it took two minutes to program the speedo for single cylinder, number of coils, 2 or 4 stroke, tyre circumfrence and number of magnets for the pick up. :oops: It's a bit rude to ask another man to see pictures of his tool!!! :oops: Where's yours?
Chalks
Postby duncmac » Sun Jan 13, 2013 11:07 am
Here you go.
I've got a bsm carbon pipe to go on (used ebay job), but want to look at getting a link pipe made up that'll take slip ons.
Other than that some new bars, maybe and R6 clutch lever and master cylinder and a PR3 rear tyre.
duncmac
Postby Chalks » Sun Jan 13, 2013 11:31 am
Sweet! It looks like you've just taken the wrapper paper off it! It'll go better when you junk the half tonne MZ silencer. I had a sports bike silencer on mine when I bought it but I thought it looked too big for the style of bike.
Chalks
Postby duncmac » Sun Jan 13, 2013 2:50 pm
Can you tell me some more about the link pipes in those two photos?
They look different, where did you get them etc. Me likey.
duncmac
Postby Chalks » Mon Jan 14, 2013 9:57 am
I think the connecting pipe started life on the origional MZ silencer (chopped off) and had a low level slip on can when I bought the bike, in the second photo I had a pipe made and welded on (high level). The first picture has a Yoshi YRD can from a DR650 again with the pipe chopped and welded. Caution! Hot exhaust gas will melt anything that gets in it's way so you may need to relocate your indicators and number plate if you go with the high level. They only burn until black and crispsy at which point they'll drop off! I used the number plate bracket from my 09 Tuono to drop them out of harms way.
Chalks
Previous
Users browsing this forum: Google [Bot] and 42 guests
