Baghira Aftermarket Exhaust Question
Postby adie_wood » Sat May 11, 2013 8:48 am
I have bought a Baggy with a 'G-Force' after market exhaust, not really used it much until the weather improved
I have a couple of questions:
1) Would the bike need re-tuning or jetted?
2) The bike appears to have a flat spot at low revs would the exhaust cause this?
3) it also pops when revs are shut off, I know this is common on thumpers but it seems a little excessive to me
Thanks in advance any help or advise much appreciated
adie
adie_wood
Re: Baghira Aftermarket Exhaust Question
Postby duncmac » Tue May 14, 2013 3:13 am
You can try turning in and out the mixture screw under the carbs, have a read/search about what the mix screw does. Not just on here.
Make a written not of exactly how many turns in to stop (dont screw it too tight!) so you can always go back.
Screw in = lean
Screw out = richer
This is only on the idle/low speed circuit.
If you make it too lean the engine will run hot (bad!!!!) and the spark plug will appear white.
Stock set up with stock muffler is 2.5 turns out from stop. (ie screw it in until it stops then screw out 2.5 turns) I'm stock and theres a difference from 2.5>3.2 make it smoother for me. I've heard that with aftermarket exhausts people are going out to 5 turns.
If in doubt take it to a dyno, pref one that deals with single cylinder bikes.
Heres information about a carb set up you can do http://web.archive.org/web/200212050740 ... RBMODS.HTM
Kit you can get to set it up http://www.off-the-road.de/en/Other-bik ... stiff.html
Theres also another one you can get from a german website which I cant find right now.. Anyone else ?? Bernd something or other???
Remember setting up carbs can be complicated and frustrating, so read first and choose wisely. (make notes of what you change so you can always easily go back with no guessing!!!)
Good luck.
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby handsomejackuk » Tue May 14, 2013 3:29 am
Dun Mac....
i have been trying to contact you on PM private message,and email i need a contact phone number to give to the courier, can you message me on here, or email me at aprettyjohns@hotmail.com your mobile number or a contact please
i can get the exhaust off to you then...
thanks Alun
handsomejackuk
