Skorpion and 500R Fork oil
Postby ralf » Thu Mar 26, 2020 3:38 am
Can anyone advise the definitive oil quantities and oil grades for both my 1995 Skorpion Tour which is a very early one, with 41mm Paioli forks and for my 500R which has 35mm tubes with springs of 530mm free length and a 4.5mm coil spring material which I believe are the uprated ones. My otherwise very good Skorpion User Handbook doesn’t give any info and my 500R User Handbook is similarly devoid of specifications. I’ve seen an assortment of advice on forums, including this one, none of which is consistent.
If all else fails for my 500R I will go with the Haynes manual for the ETZ251/301 which is 265cc of SAE10W but I may substitute 15W to account for the heavier engine and likely heavier braking to avoid too much dive when braking . For the Skorpion I will go for 340cc of SAE15W.
Any advice very welcome.
Thanks,
ralf
Re: Skorpion and 500R Fork oil
Postby Puffs » Thu Mar 26, 2020 5:24 am
No definitive oil quantities and oil grades from my side, just the advice to try & adapt to your liking. 251 stanchion = 35mm OD.
Btw, IMO viscosity hardly impacts diving, level does.
Postby ralf » Thu Mar 26, 2020 2:10 pm
Thanks for the advice that more oil, not thicker oil, has a greater effect on forks diving.
ralf
Users browsing this forum: No registered users and 80 guests
