Brake light problem.
Postby breakwellmz » Tue Dec 14, 2021 5:28 pm
I noticed today that my brake light stays on when i put the lights on but with the lights switched off the brake light works fine from either brake, what`s the issue here?
Re: Brake light problem.
Postby DAVID THOMPSON » Tue Dec 14, 2021 7:25 pm
some thing is wired up that that's extra or back feeding it
i have a feeling it is so simple it is stupid or will drive you nuts finding it
switch on the front or rear hydraulic master cylinders is sticking
or the pressure is not releasing when brake is not applied caused by one unit not adjusted proper
do tell me when you find what is the cause
Postby Blurredman » Wed Dec 15, 2021 3:52 am
I wonder if both illumination and brake are wired to the 21w application of the bulb?
Take the bulb out? It may even be in backwards, if that's so possible... (?)
Postby dickl » Wed Dec 15, 2021 4:35 am
It's my life's ambition to be like a broken brake light.......no sign of slowing down! Sorry, that probably didn't help! Hope you get it sorted.
dickl
Postby ralf » Wed Dec 15, 2021 12:16 pm
Bad earth connections can cause all sorts of weird things to happen with lights. Try checking the earth continuity. Worth a try.
ralf
Postby breakwellmz » Mon Dec 20, 2021 11:25 am
Well i sprayed some WD40 into the bulb socket yesterday (It showed signs of dry corrosion) and when i put a new bulb in today it all worked as it should, it must be the miracle of Xmas! :D
Postby Puffs » Tue Dec 21, 2021 4:17 am
Nah, WD40 is our friend.
