I'm 6'2" and 100kgs and want to know if i can adjust the rear shock on my BP so that the bike doesn't sink so much when I get on it?
I know it as adjusters on it but not sure what should be what.
Any advice please?
keithcross wrote:To adjust the suspension for your weigh (if required) you need to adjust teh preload on teh rear spring. This is done by tightening the nuts on teh top of the spring.
Adjusting the front end is a bit more tricky. Spacers will have to be instaled in teh fornt forks. One way of doing this is to install additional spacers of springs on top of the existing ones. Valve springs can be used for this.
There are alternitive springs available to replace the original ones.
Users browsing this forum: Google [Bot] and 43 guests
