Page 1 of 2
MZ Baghira / KTM 640 Adventure Bodywork
PostPosted: Mon Jun 22, 2020 11:16 am
by breakwellmz
Re: MZ Baghira / KTM 640 Adventure Bodywork
PostPosted: Mon Jun 22, 2020 5:16 pm
by handsomejackuk
i wonder what gear lever is on that...?
has anyone managed to get a better lever to fit, as mine is a bit home made...
suggestions please..
PostPosted: Tue Jun 23, 2020 3:48 am
by breakwellmz
That`s the setup i have on mine (No linkage) Will try and find out what i used and where it came from.
PostPosted: Tue Jun 23, 2020 8:35 am
by breakwellmz
PostPosted: Tue Jun 23, 2020 12:59 pm
by DAVID THOMPSON
this makes the shift order reversed so warn others if you let them ride it
PostPosted: Wed Jun 24, 2020 1:30 am
by breakwellmz
It doesn`t change the shift pattern David.
Cheers.
PostPosted: Wed Jun 24, 2020 4:18 am
by DAVID THOMPSON
mine is a traveller and i thought it would make first as one up if that linkage that is a fuss to make work
was done away with
PostPosted: Wed Jun 24, 2020 4:29 am
by Puffs
PostPosted: Wed Jun 24, 2020 7:17 am
by breakwellmz
Linkage on Skorpion is different to Baghira/Mastiff one.
viewtopic.php?f=3&t=7530&start=15
PostPosted: Wed Jun 24, 2020 4:31 pm
by handsomejackuk
thanks i know what to get now mine looks really ugly i try and get something like that now.... yz250...
breakwellmz wrote:Looks like it was one of these -
https://www.motorcycleproducts.co.uk/ge ... gJ5KPD_BwE
PostPosted: Thu Jun 25, 2020 2:44 am
by breakwellmz
I will check today the measurements of the one i actually fitted and get back to you, i seem to think i had more than one attempt at getting it right(or that could have been another bike altogether!)
PostPosted: Fri Jun 26, 2020 7:40 am
by breakwellmz
Hi, sorry for delay.
Its looks like it`s the upper one i fitted in the link i forwarded.
It puts the centre-line of the toe end of the lever 200mm to the centre-line of the footrest (My Beta has 190mm) fine for my size tens!
Cheers
PostPosted: Fri Jun 26, 2020 4:25 pm
by handsomejackuk
thats sounds good i measured mine last night, i cant remember what the offset was but the one you suggested sounds like its what i need...
thanks....Al...
PostPosted: Sat Jul 25, 2020 4:24 am
by breakwellmz
I got in touch with the seller of the MZ/KTM some while ago to ask him about his carb mods, this was his reply -
"The new carb is for the Yamaha Raptor/Grizzly 660. It fits the existing inlet/outlet rubbers. The mixture was set using a lambda sensor to get the jetting/needle position right. The original carb + cables come with the bike, so it could easily be returned to standard. I found the old carb hard to setup, or rather, once set it would 'drift' over time and need resetting. The new carb might not give as much top-end, but that wasn't a problem for me"
PostPosted: Wed Nov 02, 2022 2:30 pm
by 7inarow+
Hi all I’ve just come across this thread.
I brought this bike in July 22, it’s been a pain but fun, up and running even though I’ve got a list of stuff still to do.
