Hi
Just pick up this thread as I don't come here to often anymore. The problem I had with my gearbox was a worn selector drum. The wear was in the track that operates the 5th gear selector fork and allowed the gear to slip out, occasionally slipping back into 4th.
As I already had another engine from a XTZ660 Yamaha siting in my garage, I just swapped them out.
I really must get around to rebuilding the old motor though as it is quite handy to have a spare around.
BTY this is the 2nd engine I have replaced. The first suffered from engine failure. When I took it apart I found the following
Big end failed
Oil pump shot, I think due to parts of the big end going thorough it
Piston and barrel with severe seizure markings, not sure if this happened at the same time though
Not to sure why the engine failed as I had always changed the oil regularly and didn't over rev of run the engine at low revs on high throttle openings either.
For reference the surfaces of the gears were unmarked after 35000 plus. On teh engien with the failed gearbox all gears are still ok as well.
I only use the Baggi for fun now as I retired it earlier this year and brought an Aprilia 660 Strada. Compared to the Baggi the engine is a lot revier than the old XTZ engine with what appears to be a little more top end power. It nowhere as sweet an engine at lower revs though. In common with the XT660X & R Yamaha's the bike suffers from surging between 3 and 4000 rpm. A lot of owners are using power commanders to get over this problem as neither Yamaha or Aprilia seem to be able to cure it with out the later electronics utilizing a Lambda Sensor.
Both bike as still nice to ride though. Completely different to each other and my 1500 Goldwing
