what exhaust will fit
Posted:
Fri Jun 06, 2008 11:20 pm
by ozzieowl
i am wanting to no if any race can will fit my baghira and will it affect purformance,cheers john.
Re: what exhaust will fit
Posted:
Sat Jun 07, 2008 11:12 am
by BlueRidgePanther
I like the m4 slip-on can, personally. With the jet kit, it gives you a wee bit more power.
Posted:
Sat Jun 07, 2008 4:28 pm
by Sue
Found the UK M4 website, are the cans bike specific? which one is suitable for the Baghira?
(Sorry if its a "blonde" question)
Posted:
Sat Jun 07, 2008 9:04 pm
by OLDMTNCARVER
Have a Carbon M4 on my Baghira and tried the Dyno jet kit, really bad!
Don't mess with the carbs is my advise.
Go for Mikunis or Kiehins, (Don't comment on the spelling, I'm tired...)
Tons of posts about that the carbs...
OMC
Posted:
Sat Jun 07, 2008 9:11 pm
by OLDMTNCARVER
BlueRidgePanther,
If your carbs have the Dyno Jet kit, what are the jet sizes and the clip posision.
Any help would be great.
My carbs, the modified ones are off the bike and I'd like to get them to a point to replace the current stock set that I just installed to get the MC running after an extended period of time.
OMC
Posted:
Tue Jun 10, 2008 1:43 pm
by hutchy
I agree don't try a dyno jet kit, I once fitted one to my xtz 750, it was crap on every setting so that went in the bin( exspensive waste of time)
BSM do a couple of cans and link pipes, have a look at david silver spares as he is a supplier of BSM exhausts
Posted:
Tue Jun 10, 2008 5:04 pm
by handsomejackuk
bsm vampire is great piece of kit go for that one you wont be sorry also get the removalbe DB killer you can put it in then when you want a quiet ride comes with link pipes cost about £200 really good fit and good clamps with it also nice finish on the end can check out my pics on
http://www.flickr.com/photos/25719146@N06/cheers Al
Posted:
Sat Jun 14, 2008 2:07 am
by Sue
Thanks for the tip Hutchy, currently temporarily out of stock, but will see about getting the BSM Vampire can when they are back in stock. Do I need to do anything to the bike once fitted? Or is it just a straight forward swap over?
Posted:
Wed Jun 18, 2008 3:13 pm
by hutchy
Hi Sue, the only mod you might need to do is lift the throttle needle in the carb by one notch, but most of the time you can leave it as stock unless you like to screw the nuts off the motor then you may find it runs too weak on the standard setting, resulting in burt exhaust valves(exspensive), also I agree with handsomejack about the db killer ,good luck ...hutchy
Posted:
Fri Jun 20, 2008 3:06 pm
by Sue
Thanks hutchy, really appreciated. I can order my can happily now, and will get the needle adusted in the carb. (though will see how it rides first, it's not often it gets pushed all the way to its limits, but is fun when it does)
Posted:
Wed Jul 16, 2008 8:46 am
by Atomic Punk
I have a BSM Vampire on mine too. As someone who recently stopped next to me at the lights commented "That sounds cock on!"
Posted:
Wed Jul 16, 2008 9:27 am
by handsomejackuk
i had a bsm future on mine, then when i heard a vampire, i decided to get the vampire end can, I have a DB kiler fitted on mine, sounds o.k. with the db killer fittted but better with it out only takes a few mins to remove and i usually carry the db killer in my pocket, with an alllen key if plod is about.
Jak
Posted:
Fri Aug 08, 2008 9:34 am
by scholsey
Atomic Punk wrote:I have a BSM Vampire on mine too. As someone who recently stopped next to me at the lights commented "That sounds cock on!"
Hi, with the Vampire exhaust is it marked on the can " Not for Road Use " ?
Posted:
Sun Aug 10, 2008 5:23 am
by Sue
scholsey wrote:Atomic Punk wrote:I have a BSM Vampire on mine too. As someone who recently stopped next to me at the lights commented "That sounds cock on!"
Most people I know with that on their aftermarket cans have it rubbed off. Depends who does the MOT's as to whether they pass it or not. Some have had to put the standard can back on, and some have got away with it with the db killer in (do the latter with my CBR).
Posted:
Mon Aug 11, 2008 9:22 am
by Atomic Punk
I had my Baggy MOTed last week with the Vampire and no db killer fitted, no problem what so ever
