Removing/replacement of fork top nut-Sealant needed?
I need to remove the fork top nuts on my Skorpion Traveller so that I can take off and loosen up the Tarozzi handlebar bits to make adjustment possible.
Do I have to use any sealant when I replace the top nuts? If so what type? I know Bill Jurgenson has a link to a list of Loctite sealants on the mzriders forum. It's not easy to pick out something for general purpose use. I would also like to use said sealant for sealing the thread around a fan switch sensor I will need to replace later on.
There is also an 'O' ring under the nut (according to the parts fich on Grahams website), does anyone know what size it is?
Any ideas?
Thanks.
David.
Any ideas?
Thanks.
David.
