Baghira Rear Sprocket Bolts
Posted:
Sat Jun 13, 2009 11:26 am
by funmonkee
Grrr, I attempted to switch over to a newer rear sprocket and found that 2 of the rear sprocket bolts are rounded...Grrr
Has anyone got some ? Name your price. Thanks
PS Anyway got a quick way to get these buggers out when they're rounded?
Re: Baghira Rear Sprocket Bolts
Posted:
Mon Jun 15, 2009 7:55 am
by Stuart109
Hi
If I remember correctly a couple of mine sheared off trying to get them out. I removed the wheel and took out the drive. The bolts protruded through the back and I was able to get a grip on them to unscrew them.
I replace the Allen bolts with hexagonal head bolts.
Stuart
Posted:
Mon Jun 15, 2009 1:12 pm
by funmonkee
cheers dude, that sounds like a plan. do you have any spare hex bolts that fit? I could never get the correct pitch for those bolts last time this happened...
Posted:
Thu Jun 18, 2009 1:19 pm
by ronny60
Hello ,
The exact dimensions are M10x40 ( Pitch 1,25mm) with hexagonal head.
The original ones seem to be of a real poor quality.
For removing you better heat them.
Today I ordered a new chain and sprockets and I real hope I don't run in the same problems .
Grz,
Ronny
