suspension settings
Posted:
Wed Mar 30, 2005 4:26 pm
by bry_d
hello all i'm looking to have a muck about with the suspension settings on my black panther to get it to feel a bit more planted on the road . i was wondering what you guys have yours set at as mine is on standard settings and i think the front end seems a bit soft at the moment and the back is a bit vague
all ideas welcome
cheers
Posted:
Wed Mar 30, 2005 4:45 pm
by keithcross
Hi
I just wound the settings on the damping up 2 clcks all round. Seems to help.
You could wind the rear spring up a bit,but to change the front requires either a new spring ora spacerto increase the pre load.
Posted:
Fri Apr 01, 2005 4:07 pm
by boysie
Well, I know it's out of character, but I wound the rear spring off slightly, then dropped the forks through the yokes about 12mm ( this requires spacers under the bar clamps) also remove a further 6mm from the preload spacers that reside under the springs, along with a good quality fork oil..
What this does in affect is not to make the bike softer, just make it ride a little lower [fine as ground clearance isn't an issue for road use] and speed up the steering slightly.
Posted:
Wed May 17, 2006 4:19 am
by andyw
boysie wrote:Well, I know it's out of character, but I wound the rear spring off slightly, then dropped the forks through the yokes about 12mm ( this requires spacers under the bar clamps) also remove a further 6mm from the preload spacers that reside under the springs, along with a good quality fork oil..
I'd be interested in more info - what fork oil? - spacers for fork clamps??
Posted:
Wed May 17, 2006 2:50 pm
by BRAAAP !
I would recommend making a note of the standard settings before you fiddle or you could really mess the handling up and not know what to set it back to. . .
or was that just me ?
Posted:
Sun May 21, 2006 11:05 am
by andyw
Yes, learnt that one the hard way
Bump..........anyone??!!
