Screen for a Mastiff?
Posted:
Thu Jan 10, 2013 10:24 am
by daredevildave
Any tips for a screen/cowling to fit a Mastiff would be welcome? I'm told a particular BMW item might do!
Also any info about a good quality, good value chain & sprocket kits and the same for replacement headlight bulbs (including suitable replacement headlight arrangement). Many thanks
Re: Screen for a Mastiff?
Posted:
Sat Jan 19, 2013 12:25 pm
by radiograf
Posted:
Fri Feb 08, 2013 9:41 am
by daredevildave
Thanks for that radiograf I'll have a closer look.
Posted:
Mon Feb 11, 2013 3:14 am
by Black Pussy
Ive got a simson side predator on mine easy to fit and looks like a factory item.
http://www.simpson-detour.co.uk/Bikini% ... dator.page
Posted:
Mon Feb 11, 2013 9:23 am
by DAVID THOMPSON
if lamps of higher power than stock are installed ..
you may need to install a relay to protect the handle bar switch
or a relay that's already in the system but not able to handle the higher current needed
for 2 60 watt bulbs
Posted:
Mon Feb 11, 2013 1:17 pm
by Baggy_Al
Side Predator, looks good but, how much
Al
Posted:
Tue Feb 12, 2013 4:42 am
by Black Pussy
I bought mine off ebay second hand £50 and made my own brackets. I also got a carbon one for £60 off ebay for a bandit Ive sold. New its £200 for colours and £215 for carbon. Neil the guy that runs it is the most helpful guy around. Both mine had older lights and he replaced all four lights with newer models for £80 all in including postage, and repaired a scratch free. I will take a pic of mine later and post it for you to see. Cheers Mick.
Posted:
Tue Feb 12, 2013 4:44 am
by Black Pussy
Forgot to say I am converting to LEDs all round as the charge system can only cope with one dip or one main. Both at the same time is drain on the system. Mick
