stop and side indicators not working
Hi, this morning while coming to the office I had a double bad surprise: the side indicators don't work, either left or right. Then when I stopped I had a look to the tail and.. I noticed that the stop doesn't lights on.
I had a look to the rear lamp and is ok, then I checked the fuses and they seems to be ok (I just have to look better the 3,5A, it is so thin and with the poor morning light I could't be sure).
I have not the electric schema with me, so I can not chek if they are on the same electric line.
Any idea about what could happen? It sounds strange that the lights "wigwag" and front stop switch broke at the same exact time (the rear brake switch is broke since months: i have the spare part, but I can not unplug it from the nut and insert the new one, yet). Just to know, where is located the side lights intermittence? It is under the seat, the white componentclose to the fuses?
Two days ago i cleaned the left "commands" by using a cleaner spray for electric contacts, and put some grease to protect from the humidity (it is raining a lot, and the light button is broken so some water could enter). And two weekends ago I noticedf a black wire that had a light scratch on the protection, so i soldered it and put a thermic insulation on it. This evening i will check better if some wires could have the same issue, but I think is not the case: i had a deep look, two weekes ago, and everything was fine, and in addition i put some plastic protection to each wire.
Thanks a lot, I have also my old Africa Twin stopped because an electrical problem and I need at least a motorbike in perfect conditions to come to work
