DAVID THOMPSON wrote:see picture below
location 1 a hole on bottom of motor may weap some times
but if you get a lot here it may be a bad waterpump seal
there is a drain hole here to let water out if the pump seal fails
item 2 the over flow tube may get some here if system is too full
in very hot weather there is no catch tank like on a car
for a bunch of info on your bike go to the search page of the site
and do a search for "poster"
or click on this link
http://www.mzriders.com/viewtopic.php?t=804
ar dave
jbthumper wrote:are you sure it's petrol??how did it get up the???![]()
BUT if it's the engine oil...just tighten those screws on the head cover..(not too tight,though)
for the coolant problem,tell them to check ALL of the hoses....including the small one which links the two piece radiator together...most likely it's a leaky hose...
hope this helps!
Users browsing this forum: Bing [Bot] and 6 guests
