Starter clutch
PostPosted: Thu Jun 19, 2008 6:25 pm
by vitesse7749
Has anyone not had a problem with the starter?
Is this a matter of oil change intervals or other variables or is it just a very weak part.
I'm just trying to avoid the avoidable if at all possible.
Has anyone attempted a rebuild repair of the failed clutch or is this just wishful thinking.
Working on old British iron there are fixes that can be rendered.
R :shock:
Re: Starter clutch
PostPosted: Fri Jun 20, 2008 7:02 pm
by DAVID THOMPSON
grahams in the uk and hope the have it
http://www.grahamsmotorcycles.com
if it becomes unobtainum i will see if i can think up a home repair
plus the thing likes lots of nice fresh clean oil
change oil and filter often
i use shell rotella t in 20-40 w
Re: Starter clutch
PostPosted: Mon Jun 23, 2008 6:13 pm
by vitesse7749
Thanks muchly, I had a feeling the life was in the oil. The filter is a BMW F 650 I'm told. The rotella is mineral non synthetic? 20/40 is the correct weight? :shock:
Re: Starter clutch
PostPosted: Mon Jun 23, 2008 8:29 pm
by DAVID THOMPSON
do not run bike backwards in gear and let clutch out with a stopped motor you will pop it
both times i killed mine going up a hill and stalled on wet grass and let the clutch out to stop my self
as front wheel brake was not stopping me this ran the motor backwards against the sprag killing it bang....
