Newbie on the scene of Mz's
Postby MZLUKE » Mon Oct 11, 2010 1:17 pm
Hey all, my names luke,Im 17 and I have a 1984/5 ( cant remember :-D ) etz 125. Ive had it for 7 months know and I have had ALOT of break downs, from rubbish in the carb to not starting to electrical problems, points etc.
The rubbish in the carb is sorted out know, ive fitted a 2nd in-line fuel filter,cleaned the carb out far to many times that Id like to remember lol the points and condenser are replaced but I still have this problem
Its not charging the battery? However this is the catch, when you put a meter over the battery when its running it shows 12volts and when you rev it up around 14 volts so its charging?
The battery was new around 5 months ago and have never been run flat??
second problem, popping and farting but only ocasionally :? its only when you open the throttle it does it and can be a little dangerous if your overtaking as its quite a violent jolt
The plugs burning perfect, the pistons perfect, the bore is perfect and smooth ( no lip) so I am at a loss with it to be honest
Has anyone got any idea's what my problems could be?
thanks in advance
luke
MZLUKE
Re: Newbie on the scene of Mz's
Postby big al » Mon Oct 25, 2010 2:22 pm
hi luke,your problems can be so annoying and hard to put your attention in the right area but your going in the right direction ,go through it methodically , checking spade connections are firm and dont pull off easy, clean up the earth connections try new condenser coil etc, read my thread on supa 5 charge problems , ive been run ragged and all along it was my plug cap . Persevere and you ll get there, ive had a few etz 125 s and they are very robust and reliable.
alan
big al
Postby MZLUKE » Sat Jan 15, 2011 3:53 am
Thanks mate, I took it off the road over winter due to the problems I have been having so I have decided to give it a little TLC, I am looking at getting a new fuse box
http://cgi.ebay.co.uk/6-Way-Universal-Q ... _500wt_922 Like this but with more/less blades
I am also going to replace the coil, condenser, and points, regulator, brushes, plug lead and cap and IF I can find it a new wiring loom, new indicators, throttle, rear brake light and a general paint up to get it fresh ready for this years commuting. I dont want to spend too much on it but need it to be reliable and not to break down
Also tyres too, I am going to try and find a more modern set of tyres aswell to modernise it a little. Id like a front disc conversion as mine is only drumbrakes but dont think I can afford it :cry: :cry:
I will post a build thread up when I start the strip down :-D :-D
MZLUKE
Users browsing this forum: Bing [Bot] and 20 guests
