Rear suspension
Posted:
Tue Nov 15, 2005 10:05 am
by JulianMZRotax
I need to lower my Saxon Tour 500. Would it be OK to replace the rear dampers with 350mm ones insted of the 360mm originals. That 15 mm should be OK for me . The only passanger I carry is the misses and shee is a light weight at 48Kg.
Thanks for your help
Julian
shocks
Posted:
Wed Nov 16, 2005 7:37 pm
by DAVID THOMPSON
probely work ok and will slow down the quick steering a bit
hagon probely makes a set
Posted:
Mon Dec 05, 2005 7:28 am
by JulianMZRotax
Well I changed over the rear dampers at the weekend. Was quite prepared to move the front fork sliders up 15mm as well. But as surgested by a friend I tried it out. It did make much change to the way the bike handles. The only problem seems it's a longer drop off the centre stand but I can get used to that. Now I can put both feet on the ground.
Julian
London 6C
saxon tour
Posted:
Mon Dec 05, 2005 10:02 am
by DAVID THOMPSON
what brand and part number did you use
and the bike has quick steering stock and in the usa the oem size rear tire
is not sold and the 120/80-16 we fit here makes it even quicker
Posted:
Mon Dec 05, 2005 10:44 am
by JulianMZRotax
The units are stock MZ 250 without adjusters They are set on the hard setting. The rear tyre is a Michelin M45 350- 16.
Julian
Re: shocks
Posted:
Mon Jan 16, 2006 9:58 am
by Gromit
DAVID THOMPSON wrote:probely work ok and will slow down the quick steering a bit
I'd agree - anything to slow the somewhat nervous steering of an ETZ is definitely worth having - the bikes handle sweetly but I'd trade some of that super-quick steering for a little more stability in the corners.
Great fun little bikes though and tough as they come
steering
Posted:
Mon Jan 16, 2006 10:07 am
by DAVID THOMPSON
i do not give test rides to others on my saxon tour
the bike is ok for me but i dont need a friend to bust his ass on it
because of its to steep fork angle
