Electrics Again
Hi all ,
Problem with the TS 125 again.
When I put the main lights on the engine cuts out.
I have had a look around the posts at similar problems but apart from putting in a new battery other peoples solutions are hard to find.
Anyway here's what I have done and found , replaced points and condenser , replaced battery with 6v 14Ah SLA , replaced reg with solid state one , replaced fuse box with 2x in line fuses , repolarized the dynamo.
Unfortunately when the bike ticks over and I switch on the headlight the battery voltage falls away from 6v to about 5v and the engine misses and cuts out , what I have noticed is that the battery is not charging at tickover ( amp meter inline ) but the charge light is off ??? . When I rev the bike it charges at +6 amps @ 7.5v .
The wiring all seems ok and I have checked the connections for the charging / ignition , I'm thinking now that maybe the brushes are at fault , has anyone else had a similar experience ?
Thanks in advance.
Rich
Devon
1986 TS125 Alpine
Thanks in advance.
Rich
Devon
1986 TS125 Alpine
