ETZ Carburation
I now have the ETZ 250 that I bought a few months ago running but.......
Although an EZT 250 it has a later carb from an ETZ 251 fitted, but I am assured it should run OK with it.
Problems / questions are:
1. It starts with no choke - new plunger fitted, slack in cable so in theory should work OK or do they all start with no choke?
2. I have the air screw set to 2.5 turns out, and bypass screw 4 turns out as per the Haynes book of lies - can anyone confirm that these are the "base" settings?
3. If I blip the throttle it does not pick up as quick as it should, and then when you rev it, it takes quite some time to settle down to a nice even idle - any thoughts on fixing this ?
As far as I know crank seals are OK (usually starts first kick and easily), timing is set at 2.5 degrees BTDC again as per Haynes manual - is this correct setting? Air filter is new and I have checked float height.
Needle and jet look a bit manky so probably replace them anyway.
Any suggestions to improve things ?
Cheers.
Cheers.
