ETZ 125 carbs
Posted: Tue Aug 20, 2019 12:48 pm
Hello, new here...
I have acquired an ETZ125 which doesn't run particularly well (spluttered to a halt and made me push it up a hill!), fuel tank was rusted up and blocking the petcock badly (but seemed to run ok after cleaning this out), so I assumed it was this it... Anyway, have had the tank off and given it a really good clean removing the vast majority of the rust, also installed an inline filter... Ran about a pint of fuel through the petcock and didn't collect anything in the filter so am happy the fuel supply is now good...
Removed the carb and open it up, all the installed jets were as the Haynes manual with the exception of the main jet, the book specifies a 100, I have 115 fitted. The needle was badly worn/corroded, however with nothing to hand to replace anything I gave it a little clean and refitted...
Also to note, I went to inspect the air cleaner to see if it was fouled, only to find it missing! will get one ordered... And on a 5 min look the timing appears to be a little advanced (~3.5mm BTDC, the Haynes says 2.5mm). Also, pending the level in the oil tank going to down to make sure the pump works, there is a gallon of 50:1 in the tank not strait petrol.
Does anybody have any suggestion with what to target first? I have been looking to see if I can pick up an after market carb, however only see the 24N2 (presumably larger for the 150) carbs at reasonable prices (the one fitted to the bike is 22N2), however looks like I can get the jets specified in the haynes book for mine... Does any body have axperience of runing the 24N2 carb on the 125? or advice on how to jet it?
Any help suggestions etc greatly appreciated!
Kev
Kev
