Batteries
Batteries
Postby basser23 » Wed Nov 29, 2006 11:16 am
Hey all,
Anyone have a recommendation for AGM type battery for a Sport?
Would like to get about a 10ah, 140 or so cca...
Chip
basser23
battery
Postby basser23 » Wed Nov 29, 2006 5:12 pm
When searching the data base,I came across some posts regarding an
Interstate ytx12-bs..this was used in several Baggys..What I noticed when
researching this is the polarity of the terminals is reversed from the Sport
YB7L...Does the Baggy use a left positive post?
Curious..
Chip
basser23
Postby edec » Thu Nov 30, 2006 6:19 pm
My 2001 Baghira has a right positive post.
edec
batteries
Postby basser23 » Fri Dec 01, 2006 8:50 am
EDEC,
What battery are you using? Im looking for more ah and cca than the yb7l
provides..
Chip
basser23
Postby edec » Fri Dec 01, 2006 11:41 am
My stock battery (Deta 9ah) has just died recently, so I too am looking for a replacement. If you get any good suggestions/alternatives let me know :wink: Thanks, Ed
edec
Postby LWS66 » Fri Dec 01, 2006 11:57 am
Westco has highly rated batteries, with better numbers than the Yuasa in most cases, they are AGM types I believe.
http://www.westcobattery.com
LWS66
Postby steveweck » Fri Dec 01, 2006 10:53 pm
Regardless of what battery you settle on you should always have some type of trickle charger. Whether its a Deltran Battery Tender or an Optimate it will improve your batteries performance over the long haul. Think about how often you actually ride your bike compared to how long it sits in the garage waiting for you to get off your ass. A battery loses a certain percentage of capacity each day it sits. A (smart) trickle charger will keep your battery at capacity until you roll off the couch and strap on your helmet and ride the hell out of you bike. Cold weather also effects the battery so if your able to keep the bike inside its a plus. Idling the bike every now and then doesn't really help as the charging system doesn't do much at low rpm. To make it easy the manufacturers of the trickle chagers make pig tails or connectors with weather proof caps that you can install on the battery so you can plug in the charger without having to remove the seat or body work. Although its a conflict of interest for me, I'd recommend the Optimate for the sealed AGM batteries as it provides a desufating phase in its charging process. Don't ask me about that, look it up for youself as I'm sure its on their website somewhere.
Well, Thats all I have to say about that Bubba.
Steve
steveweck
batteries
Postby basser23 » Mon Dec 04, 2006 9:27 am
Went to ebatteriestogo.com,found a 7ah 140cca AGM for about $50..
Will order today I think...
Chip
basser23
batteries
Chip
basser23
Flattery
Postby sapperk9 » Mon Dec 04, 2006 2:17 pm
I recently fitted a Yuasa 10LB.
Just fits in the slot in the Traveller, a small mod needed to make the rubber retainer fit. No big drama.
160cca, Excellent!! :D
"In questions of science the authority of a thousand is not worth the humble reasoning of a single individual." - Galileo Galilei
sapperk9
Users browsing this forum: No registered users and 216 guests
