MZ DIY 150 conversion success
Postby mxsteven » Thu Dec 21, 2006 8:35 pm
Here the pics of my bike....
the Back mudguard had been removed and the air box had been removed too... battery located in the middle...
I had some problem with the block which the water jacket leaking from the outside, so i solved the problem with gasket sealant.... till now it works fine..
Will update more pics later...
Regards
MXsteven
Engine View and air box compartment being removed
Back view of my bike
Where u go, it's up to u,
Think b4 u do, Ride safe.
MXsteven
mxsteven
conversion
Postby DAVID THOMPSON » Thu Dec 21, 2006 9:43 pm
what piston did you use and did you use a steel liner or have some one
redo the nycil bore in the alunium cylinder
ar dav
Postby mxsteven » Thu Dec 21, 2006 10:28 pm
i used the local bike 175cc piston... and rebore using hardened steel liner which pin end piston also need to be mod....
i also did smoke post and polish for intake and exhaust... tommorow im going to replace my carb. I havent decided what type of carb to change so i will try a few type of carbs and see which is the best.
MZ had a bug in the ignition... try to replace the ignition relay which is beside the CDI (white colour relay which had 5 pins) you can replace it to a normal automobile relay which you only use 4 pin.
2 pin for the relay coil and 2 pin for NO (normally open).
it improves the idling because the original relay had some current restriction in it which that 12v in but 5 - 8v out only and sometimes 3v only, then it will make some misfiring during idling.
Regards
MXsteven
ps: later i will take some technical picture and post it in
MXsteven
mxsteven
Re: MZ DIY 150 conversion success
Postby DAVID THOMPSON » Sun Oct 28, 2007 9:53 pm
on my rt125 wire drawing relay 19 supples power to cdi
and is wired to sidestand safety switch
if it goes bad it can cause several problems
on bikes with a tachometer bad tachometer readings
poor bike running
bike will not run at all
same problems as steven noted above
use search for relay 19
on my bike it was very small and contacts were burn up
ar dave
Postby jeremy » Sat Feb 09, 2008 6:57 pm
mr ssteven iam from malacca i got my bike like one year ago just wanna know wat carb are u usin for ur bike ..cause my bike doesnt have pick up need ur help?
jeremy
Postby kim » Tue Mar 04, 2008 3:33 am
Hi jeremy
Have u use any aftermarket exhaust,...if not,try one...definately will help ur bike move better,but speed wise wil b similar.
Try remove d snorkle under d seat(air-box),it help the bike breath better...change to aftermarket exhaust like AHM,Hurricane or else....
Carb,....pls don't change it cos it only help u 2pick better,but not d speed....means waste fuel....
Hope this wil assist...
The fun of using MZ125SM is that u can get away in the traffic (provided your bike is manage to slot in those narrow lanes),
kim
Postby Igor » Tue Mar 04, 2008 12:02 pm
Are you serious? You recommend him to remove air filter?!
Igor
Postby kim » Tue Mar 04, 2008 7:55 pm
Don't get it wrong pal,....Just d snorkle head (the air intake hose)not the whole air-box
kim
Postby DAVID THOMPSON » Tue Mar 04, 2008 9:33 pm
i did the snorkle remove and a foam filter but could find no jets for carb in the usa
and it just made the gas miles less and the bike run slower
Postby Igor » Wed Mar 05, 2008 2:25 am
kim wrote:Don't get it wrong pal,....Just d snorkle head (the air intake hose)not the whole air-box
Uh, I'm sorry.
Igor
Postby kim » Wed Mar 05, 2008 4:32 am
Dave
mine,i remove d snorkle head & install a customade caniste,...i runs well than stock canister (less restrictive)....but top spedd +- 5kph different only.....
kim
Postby DAVID THOMPSON » Wed Mar 05, 2008 12:10 pm
just removing the snorkle made mileage worse
as i can find no jets here in my location
Postby DirtGrinder666 » Thu Mar 06, 2008 2:23 pm
in KL..I have some crazy friends changing their 125SM/SX stock engine to a modded 150cc 2 stroke or a 4 stroke engine from other manufacturers like kawasaki,honda etc...the result...the bike capable to run at 100mph = 160 kph or crusing on a sustaining speed up to 170kph.. that would make it run as fast as a BWM 660 SM..the cost is damn cheap as low as RM1800.00 = USD 514.00...(anyone live in KL/Klang Valley area could refer ur bike to Usop's Scrambler Workshop (just a small DIY workshop)...located just beside the MRR2 hiway near Taman Melati) :smt006
-STOCKBIKERS if you know what i mean-
DirtGrinder666
Postby Igor » Thu Mar 06, 2008 3:30 pm
kim wrote:Dave
kim, can you picture how've you made your costum canister?
Igor
Postby kim » Thu Mar 06, 2008 8:58 pm
Dear Igor
Those canister were sent to exhaust shop for customade.....reason being they tailormade your exhaust according to the shape & sizes you want & at the same time,they know what is best for your bike,....if you get an aftermarket canister that has been made to cater for all the 125cc,i will be saying there are differs in every 125cc engine.....even they engine configuration were also differs.
if u wanna the step by step photo,..i won't be able to do that...cos i don't fabricate those canister myself.
kim
Return to 125 cc
