How big is too big??
Postby jbthumper » Mon Dec 25, 2006 12:19 pm
Welcome and thanks for sharing Tom.
Do you think that a 32mm carb would do a better job over the 28 with the 150 kit on??
Because looking at the Honda CRF150R specs,it has almost the same spec as the 150 kit(bore & stroke wise) but the crf is utilising a 32mm pumper carb.I'm not sure about valve sizing and port flow for the crf,though.
Cheers.
Merry Christmas!
:smt033
jbthumper
Postby mxsteven » Mon Dec 25, 2006 8:31 pm
oh!! i really need a bigger carb... i can feel that my carb is insufficent. 32mm carb? if it can fit why not! but i do really need some carb setup guide for my bike. now mine is 147cc, everytime i ride i felt my bike lag of air after 7000rpm!
Tom, what type of carb are you using now? can you share with us what is your carb configuration? and also thanks for your very infomative info on above reply!
regards
MXsteven
Where u go, it's up to u,
Think b4 u do, Ride safe.
MXsteven
mxsteven
piston
Postby DAVID THOMPSON » Mon Dec 25, 2006 8:49 pm
tom do you know if anyone has a supply of the wisco pistons
or the wisco part number
as i can make a do it my self job of it if i can get the piston and rings
and the piston fitting sizes
mx steven what piston did you use
ar dave
Postby mxsteven » Mon Dec 25, 2006 9:08 pm
im using the local bike aftermarket piston here or you can refer to the same piston kawasaki 175 (if not mistakken) Hmmmm JBthumper knows the best coz he was spying way much on my bike!!! :-D
regards
MXsteven
MXsteven
mxsteven
Postby jbthumper » Tue Dec 26, 2006 2:26 am
actually Steven, I only saw your bike's internals before the upgrade...I think only Jan saw the big bore and all... = i don't know jack s*!t :-D
all i do is "assuming" :P
Dave, the piston that Steven is using is from a local manufacturer(Modenas) from a model named Jaguh(refer http://www.modenas.com.my )...
it had a longer stroke, so what they did (i assume :D )was decked the piston's top to match the stock stroke while keeping the same piston bore...
a few lines of my assumptions ;-) :-D
Regards.
:smt033
jbthumper
Postby mxsteven » Tue Dec 26, 2006 2:41 am
The stroke remains the same but the bore is diffrent (i can't recall how many mm). Total is 147cc as per caculated, the water jacket cylinder wall had been reconstruct. Well have to get back my book to see what had been mod! i have forgotten most of them!
regards
MXsteven
MXsteven
mxsteven
Postby Tom T. » Wed Jan 03, 2007 6:21 am
I trust you all had a good holiday season, and that all are safe and well. To answer jbthumper regarding carb size, in my case the 28mm flatslide was 'Plug & Play' on my bike as it came from that expensive German company. To be fair, it was quite a comprehensive kit, with a bored manifold etc., etc..
I have not taken it to a larger size as at 28mm it works so much better than the stock carb (which is a terrible carb), and so well with the other mods, that it is not worth messing with it any further. I had had a flatslide on one of my previous Harleys and it was a crisp performer just like its 28mm little brother.
Incidentally, fitting this carb into place is not easy, and requires some patience. There is barely enough space to fit it in.
All the best for the new year!
Tom T.
Postby mxsteven » Wed Jan 03, 2007 9:26 am
Thats why i removed the big air filter! now i re-customised my air filter box which is smaller and efficent (hopefully :P )
regards
MXsteven
ps: Ohhh Happy new year to everyone and cheers to myself which i have gotten a wireless broadband better than Stupyx (streamyx :D)..
no more TMnut opppss i mean TMnet hehe :P
MXsteven
mxsteven
Previous
Return to 125 cc
