Rear suspension set up
Postby keithcross » Sun Feb 25, 2007 3:22 pm
My 17 year old son has a 125 SM and is having prblems with the rear suspension. I think it needs a bit more preload.
He weights 15½ stone, 95.25Kgs or 210 pounds.
Any ideas?
rear spring 125cc
Postby DAVID THOMPSON » Sun Feb 25, 2007 6:28 pm
here is shop manual on the rt 125
hope this helps i weigh 220 lb and mine is still set to factory setting
search words rearshock rearspring
mz125cc shock.JPG (135.83 KiB) Viewed 3437 times
Postby Drew » Mon Feb 26, 2007 9:22 pm
FWIW, mine's pretty much cranked up all the way (185 lbs w/o gear). I'll double-check that tomorrow. It was set up that way by a suspension specialist at the last trackday I went to.
Following that, Wilbers makes a rear shock assembly (I think the PN is 630-603-00), but that's probably in the ballpark of $600. Whatever the cost, it's more than I'm willing to spend :(
Relax. You'll live longer.
Drew
Postby keithcross » Tue Feb 27, 2007 4:31 am
If your shock has been adjusted, could you measure the amount of thread showing please.
Postby janraafi » Tue Feb 27, 2007 10:56 am
yeah..i have adjust mine to be higher..coz im a six footer, but mine look still low to compare to my friends...whats with it....is mine not good anymore... :?
janraafi
Return to 125 cc
