High performance CDI box
Postby AtomicSpew » Mon May 14, 2007 10:37 am
Thanks Bill; appreciate the heads-up on the 14 tooth, but just to clarify: I'm looking for quick accelleration out of really tight twisty roads and SuperMoto tracks--usually rellatively low-speed apexes compared to street-bike tracks. My Baggy is the Street Moto version, not the Enduro version, and only sees fire roads and open trails when it comes to dirt. Also, the bike will not be used on the highway and if 85-100mph winds up being my top speed, so be it.
If the 14 tooth is a bad idea, which combo do you recommend for my style of riding?
Sorry to be such a mechanical noob--I love to ride and am trying to become better versed in the mechanics of my bikes!
Cheers-
A.S.
_______________________________________
03 Baghira
03 CRF150F (w/BBR 175 hop-up)
Stop, drop and roll doesn't work in hell...
AtomicSpew
Postby Bill Jurgenson » Tue May 15, 2007 12:05 am
If you need a new chain anyway, get a 16t cog if you don't already have it and try 16/48. You will need to get a chain with at least 120 links. You can always remove a link or two if it is too long.
Otherwise 15/44 which works with the 110 link chain.
I would use a motocross racing chain without seals (O or X-rings) because a good sealed chain needs up to 2hps for itself and I assume that's 2hp you don't have to give a way. Besides, even the very best such chain (DID 520ERT2) costs much less than a good sealed chain; as much as 1/2 as much, depending on the quality of the sealed chain.
I don't today's US market, apart from things like Megacycle and Carillo and knowing Tim Barker personally. The chain obviously presents no problem. It should be possible to get any chainwheel you need made-to-order in high grade aluminum for a reasonable price. There must be a reasonable source.
Maybe Chris Hunsicker, here in the forum, can help.
I get mine from Leonard Sieg, THE specialist in Germany:
http://www.ls-motorradteile.de/
If you can't find what you need stateside, send Claudia a friendly email
muenning@ls-motorradteile.de
stating what you want: what bike, number of teeth, pitch. He has the data on practically all bikes. Of course, he can also supply the cog.
The chainwheels are CNC milled. I get them within a matter of days.
Sieg rides a Skorpion himself.
http://www.ls-motorradteile.de/ebene3/index.html
http://www.ls-motorradteile.de/ebene2/einige-bilder.html
If you need something very special (antique, racing wheels) he just needs either a drawing or additional data like center hole diameter, Bolt pattern and whether it has lightening holes etc.
Offset chainwheels to correct chainline front to back are also no problem when one is running a different hub.
Previous
Users browsing this forum: Bing [Bot], Romjur and 12 guests
