Exhaust residue - is this normal?
Postby droy » Thu May 31, 2007 8:17 pm
Pulled off the headers off my Skorpion Sport (51,000km on the clock) and looked at the exhaust valves. I have .5 to 1mm of yellow power residue on the valve stems. Running to lean? :(
BTW - Original owner, jet kit, foam air filter and custon Barker headers are the only engine mods.
droy
mixture & yellow stuff
Postby jimc » Thu May 31, 2007 8:30 pm
I think the plug electrode condition is a better indicator of rich/lean.
Regarding the yellow stuff on the exh. valve stems, some things to look into..
Does the bike use any coolant? maybe pressure check cooling system & do a cylinder leakdown .or maybe switch fuel brands . Possible you have a marginal head gasket seal.
Good Luck
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
sulfur ?
Postby DAVID THOMPSON » Thu May 31, 2007 9:52 pm
droy what is your country
the quality of the gas may be the cause
it may be sulfur build up if sulfur content high in fuel
the high heat at valve may make it collect...
it is a bright yellow
almost the color of the yellow used to paint road lines
ar dave
Users browsing this forum: Bing [Bot] and 42 guests
