Carb adjusment with free flow exhaust
Postby Stretchy » Thu Jul 26, 2007 8:36 am
Hi, OK eventually got another MZ and is a very fine looking Melon Yellow SX. The original exaust has been replaced with a Sebring which is basically a straight through pipe with the minimum of baffle surrounding it.
The exhaust is very loud and although a bit annoying keeps people from jumping out in front of me (I commute across a busy city) so have decided to keep it on. I have noticed tho' that the bike runs a little rich and never needs any choke on startup and also tends to die if you give the trottle a quick blip. I'm going to have a fiddle with the carb this weekend and was wondering if anyone has made the adjusments to improve the mixture with any success (idle mixture screw and circlip needle position).
Regards from a rainy UK.
Stretchy.
Stretchy
Postby Stretchy » Sun Aug 12, 2007 6:24 am
Hate to answer my own question but............
I moved the circlip on the needle to the middle position (of 6) and seems to have done the trick.
Regards from a sunny (at last!) U.K.
Stretchy
Carb flow wt aftermarket exhaust
Postby kim » Sun Sep 30, 2007 10:18 pm
Code: Select all
:-)[quote] I have installed an aluminium can (produce locally)which very much noisier.Wht i did was to add an addition baffle into it(at the end of the can) & now smoother...very much less noisier..
I change the mainjet from 100 to 105 sizes,...this wil supply enough fuel to cater for the exhaust without removing any circlip inside the carb....
Happy ridin[/quote]
The fun of using MZ125SM is that u can get away in the traffic (provided your bike is manage to slot in those narrow lanes),
kim
Return to 125 cc
