I wanted to repost the link to a terrific Skorpion resource--a wiring diagram from Tony Idle of the UK who originally posted it on the Yahoo group MZOG.
If you find Yahoo as much of a pain as I do, you can find Tony's diagram on
http://www.mzskorpion.de
Click on "racing/tuning," and then the 3rd item down is the one to click on: "Schaltpläne als ZIP (0,8 MB)"
Chris Hunsicker wrote:This from a previous post:
Also, if the Baggy is like the Skorpion, a faulty tachometer can make the bike run poorly. Unplug the tach, and see if the problem goes away. I *think* the CDI boxes only rarely fail.
Chris Hunsicker, Philadelphia
Nils D wrote:Chris Hunsicker wrote:This from a previous post:
Chris, could you (or somebody else) tell more about what a faulty tachometer could cause.
My tachometer behaves normal at low speed and low revs. And it is quiet steady at 110 km/h, even if it then says the engine is running at 4500 revs, seams to low. But if I then slow down to 90 km/h, the needle bounces between 2500 and 6000 revs.
Recently my battery has started to dry very quickly, as if it is being charged to much. I have to ad more destilled water every 400 km.
What could cause this? A faulty tachometer? Or what?
Best regards,
Nils
hb7 wrote:The tach is repairable...open it up and resoldering the board worked for me.
