Tachometer
Tachometer
Postby Timan » Wed Feb 13, 2008 9:40 pm
I would like a tach. on my Baghira. Has anyone found a simple solution? Thanks in advance.
Timan
Re: Tachometer
Postby Garf » Thu Feb 14, 2008 3:40 am
The mastif runs a tach so you could use one of those. Alternatively you could replace the standard speedo with an electronic aftermarket one .....there is one available in the UK originally for a Raptor fitment which I think is about £80 from memeory ......sadly I cant remember the supplier at the moment !!
HR Black Panther
Garf
Re: Tachometer
Postby Garf » Thu Feb 14, 2008 4:20 am
http://www.acewell-meters.co.uk are one possible supplier.
HR Black Panther
Garf
Re: Tachometer
Postby claytonb » Thu Feb 14, 2008 4:35 am
Would this arrangement cripple your battery if you dont use the bike for a long time,garf?
Clayton
claytonb
Re: Tachometer
Postby Wonkmeister » Thu Feb 14, 2008 7:49 am
We supply these tacho/speedos and the one fitted to mine was left plugged in for nearly 7 months, the battery still had enough life to turn the bike over! They are extremely low voltage...no worries!
Wonkmeister
Re: Tachometer
Postby Garf » Thu Feb 14, 2008 1:20 pm
Oh yeah, and slipstream sell 'em. Sorry Wonky I forgot that you had set up a supply when you were building the STMZ.
Is she completely finished yet with your motor and carb installed yet ?
You have been so quiet I was beginning to think you had taken your fat wallet and moved to Mexico :)
Cheers
Garf
HR Black Panther
Garf
Re: Tachometer
Postby kendo » Thu Feb 14, 2008 2:41 pm
I purchased 1 from M and P for my Baghira, it took a bit of doing but after a few phone calls to M+P and their supplier i eventually got one. I mounted it onto the top yolk and connected up 4 wires and away it went with no problems. I you are ordering one make sure you ask for one that has a 60mm black face, goes from 0-8000 rpm has a chrome body and is compatible with a single cylinder engine, if they say that they dont do one then tell them that they do and to look a little bit harder. If you are getting no joy then let me know and i will give you my name and then they should be able to source it from my last order.
Kenny.
kendo
Re: Tachometer
Postby Wonkmeister » Sun Feb 17, 2008 12:48 pm
Garf wrote:Oh yeah, and slipstream sell 'em. Sorry Wonky I forgot that you had set up a supply when you were building the STMZ.
Cheers
Garf
LMAO...hey mate. I've actually sold my STMZ to my best mate...flash git sits it next to his 1975 Porsche 930...looks awesome...i'm happy she's still in the family so-to-speak. Shes all back together in basking in her glory....
I've started the 2008 Baggy project....powdercoated frame and same forks as Whysub....looking good! Aint heard from you for ages dude, glad your on the mend dude! :-D
Wonkmeister
Re: Tachometer
Postby Wonkmeister » Sun Feb 17, 2008 12:51 pm
kendo wrote:Hi,
Kenny.
The Acewll digital units have a rev counter feed that goes directly to the CDI unit, funny thing is the CDI has one tab not being used on the Baggy and this is the feed to the digital unit that gives you an accurate rpm reading! Cheap too....
Wonkmeister
Users browsing this forum: Bing [Bot], Google [Bot], Romjur and 30 guests
