malayabird wrote:Get it at Ah Hong Jalan sentul Kuala Lumpur!!!
kim wrote:malayabird wrote:Get it at Ah Hong Jalan sentul Kuala Lumpur!!!
Hi bird....thks 4da sharing
btw,...would u mind lettin us know abt d price,...tq again
DirtGrinder666 wrote:You can use any type of rear or front signal set ... for my bike.. i'm using the transparent signal cover from MZ mosqito and it looks much more nicer.. some of my friend is using the Yamaha RXZ catalyzer signal cover and some are using BMW side signal (which cost them rm 500!) and some also using Proton Gen2 side signal cover.. actually we can fit anything to our bike except for some rare engine parts!
regarding the exhaust system.. now im using back the standard muffler.. previously i'd use HeavyDuty Endurance ,Super Trapp & AHM (very common la this one!) nothing much happened just it will increased your acceleration and make our small bike sounds like it having 250cc engine..
bout the locking cap.. I did not prefer to use that one due to it does not support the overflow tube.. but some of my friends use it alrdy since 3 years ago.. anyway in terms of safety while parking in a non-secured area it might be a bit handy ...
figure8 wrote:hi guy.... need some info.....
i had some problem while riding suddenly the engine stop ... any one know why....
thank....
kim wrote:To be frank,...it's very hard to detect if thats d situation,..probably d previous owner knows it & he didn't share with u.
So far i haven't encounter any MZ riders with these issues(those so far i come across).....
btw...how long u own d bike?....is these issues appear oly now..how frequent it "die-off",...how long does it need to be re-start again,...does ur engine creating a very loud noise,...when u let d engine idle,wil it die off?
Since u also didn't understand ths bike well,...d oly stuff u can do is to "catching" it slowly one by one item...like to start it up with d plug cabling,...the plug coil,...d wiring systems,...ignition system,....the CDI..& many more.Therefore more time & $$$ required to resolve d issue.
[color=#FFBFFF]To share with u,...mine previously were hard to start(like cranking it at least 10 to 15 second)...i change d battery(cos it oredy 1 yrs 2mth & can't charge fully),...service & change d carbon of starter coil,...i even relocate the existing rectifier location from below the air-box to fix it below the seat now & even running an earthing to the chassis cos MZ originally don't hv it....Even my regular visit mechanic,he also didn't ntice MZ recitfier were place below d air-box & without earthing connections...I even made a call to MZ Shah Alam to clarify these matter & he confirm it.[/color]
You can contact me if u think u wanna talk about these matter,but no promise i can settle it :- 012-2138227(kim)
antichrist wrote:i'm having a MZ sm125 scrambler, 4 year old, i have quite a long time(approx 1 month) never start my bike,
now i cant start it, i've brought a foreman to checked it, i was told the one-way bearing need to replace,
but the ori manufacturer have no stock at the moment, probably discontinue produce.
any1 have stock of one-way bearing for MZ SM125?
need urgently..pls help me out urgently...PM me
