hi yes ive got some silicon grease ready to apply and im waiting for my dialectric grease to arrive in the post i hate electrical problems my guzzi was cursed by these,you may be and hopfully right about the brake needing more miles ,but the front suspension really does need attention even more so when you say ur set up was initially to hard ,in fact im off for another look at itIlPrincipeBrutto wrote:Hi GED,
I have a 16/43 combo on my 1000S, and it's better than the 17/45 it came with (which is already an improvement on the factory 17/43). If you don't mind losing a bit of speed (second gear in particular feels too short now) you will not regret the change.
I find the suspension fine, I never use all the travel available, but I also weigh 74Kg, a bit less than you I think. I actualy slackened both ends a couple of clicks because the standard set-up is very hard, you can tell the biek has been developed on smooth German roads, not the crapy ones we have around here.
I found that the rear brake improves with mileage. Give it time, say until the end of the running in, and you should see some improvement. It will never be as good as the one I had on the Thunderace though, but then again, I only use it when I filter or in traffic, and I try to avoid those if I possibly can .
Last but not least: electrics. Many suggest coating the coils with grease or some other similar damp-proof material. I would also suggest liberally spraying all connectors and the switch blocks (inside them not just outside) with WD40 or something similar.
IVE NOT HAD CHANCE to "push" the bike on country roads so not sure what the set up will be like on fast country lanes,although around town theres just too much dive ,preload and damping are at max ,once ive made some abba stand adaptors and the weather really deteriorates i will try a heavier fork oil and decrease the air gap ,increasing oil level ,if theres no improvment then i will fit some harder rate linear springs,tuxracer wrote:My forks stick through the top yoke by the same amount, standard as far as I know. I'm with the other guys on the suspension and find it to hard on rough roads, however daft as it might seem I reckon the front end would soak up the bumps better with lighter oil and firmer springs as it does dive a fair bit under braking. You can adjust the spring pre-load on the front as well as the damping so might be worth you winding up the pre-load to see if it supports your weight better. As far as I can remember you turn the large hex on top of the fork legs clockwise to increase pre-load. If you want to protect your forks best to cover the spanner with tape or you can easily scrape the finish off. I found the quickest way was to take the bars of and use a socket.
If that does not improve things best give Wilbers or your local suspension specialist a call for some heavier springs.
Cheers
CHEERS TUX IT WOULD BE A GREAT HELP ALSO IF YOU COULD LET ME KNOW THE LENGTH OF EACH ADAPTORtuxracer wrote:ged
no problem, I'll take some pics of the adaptors at the weekend and post them up for you.
