Baghira parts question
Postby Sgt Rock » Sun Nov 30, 2008 3:21 pm
Would a swingarm from an LC4 and radiator fit the Baghira? I've tried a DRZ radiator but the mounting bolts are shorter and won't fit. Thanks
Sgt Rock
Re: Baghira parts question
Postby MSW » Sun Nov 30, 2008 8:11 pm
The radiator from the LC4 should fit. It appears to be the exact same radiator. Not positive about the swingarm, but I believe the Baggy's swingarm is one of the few things on the bike that was actually fabbed by MZ at the factory, so I doubt that anything would bolt right on.
Good luck!
MSW
2005 Black Panther
MSW
Postby Sgt Rock » Sun Nov 30, 2008 11:48 pm
Thanks, so if the radiators fit, I will most likely have to swap the radiator fan also. Will only having one fan create any cooling issues?
Sgt Rock
Postby wayne » Mon Dec 01, 2008 4:38 am
if you need a baghira swing arm cheshire motorcycle salvage have one for 25 quid. if its any help
wayne
Postby Sgt Rock » Wed Dec 03, 2008 8:35 pm
I sent them an email and never got a reply....
Sgt Rock
Postby keithcross » Fri Dec 05, 2008 5:34 pm
Rads on the Baggi are the same as an LC4 down to the fan. Swinging arm is a one off to MZ as far as I am aware.
