Water Pump hose
Water Pump hose
Postby kman.45 » Sun Jun 11, 2006 1:12 pm
Does anybody know if the hose that connects the intake of the water pump (points out from the front of the water pump) to the "tee" below the radiators is a Yamaha part? or just an MZ part?
thanks,
kman
kman.45
hose
Postby DAVID THOMPSON » Sun Jun 11, 2006 8:54 pm
what bike model and year
and some of these hoses can be found at auto parts stores
if you have an experanced parts guy look at what your replacing
he may be able to do it from a car heater hose he has in stock
Postby kman.45 » Mon Jun 12, 2006 9:51 am
Sorry, duh, model would have helped. 2003 Baghira. A generic hos is not going to work because it has two (maybe three) right angle bends molded into it. It fits snuggly in between the motor and exhaust pipe too, so it really needs to be the stock replacement. Just wondering if I can order it from the friendly Yammie dealer or have to call BSA Regal.
kman.45
fast
Postby DAVID THOMPSON » Mon Jun 12, 2006 12:23 pm
probely faster to just get it from phil
if you call him early tue. morning
you should get it in next monday or tue mail
phone number and fax number is on web site
and do search up above for bsa and info will show up in
a post
or link here
http://www.mzriders.com/viewtopic.php?t=1438
dont forget the time difference 5 to 6 am edt here is just before lunch
there and an early call may get it shipped on tue
Postby Drew » Mon Jun 12, 2006 3:23 pm
For my MZ, I replaced mine using CPE hose. If the bends aren't too crazy, then this is a viable alternative. Note that the 125SM has two right-angle bends...
MZ 125SM front rad hose.jpg (27.97 KiB) Viewed 4616 times
Relax. You'll live longer.
Drew
Postby Drew » Mon Jun 12, 2006 3:24 pm
This is what I replaced it with (not my bike, but it looks the same)
MZ 125SM CPE.jpg (54.08 KiB) Viewed 4614 times
Drew
Postby keithcross » Mon Jun 12, 2006 5:46 pm
Hey that looks a lot better and stronger. The hose looks real vunerable where it is and I can see it getting damaged if the bike is used off road.
Postby Drew » Tue Jun 13, 2006 1:07 pm
keithcross wrote:Hey that looks a lot better and stronger. The hose looks real vunerable where it is and I can see it getting damaged if the bike is used off road.
Thank you! The stock hose is braided, but the new one is a bit thicker and much nicer. The only drawback is that the connector from the rad is 1/8" larger in diameter than the connector into the engine. It just took a little more "oomph" to get the hose on the rad (not so much that it killed the radiator, though!).
kman.45, also consider checking the KTM parts catalogue. My rads are KTM-made, and it wouldn't surprise me that the Baggy uses rads from them as well. Try sites like KTMcyclehutt.com; I did see some exploded parts diagrams online of KTMs.
Drew
Postby kman.45 » Tue Jun 13, 2006 5:03 pm
[quote
kman.45, also consider checking the KTM parts catalogue. My rads are KTM-made, and it wouldn't surprise me that the Baggy uses rads from them as well. Try sites like KTMcyclehutt.com; I did see some exploded parts diagrams online of KTMs.[/quote]
thanks for the tip. I will do that. The hose on my Baghira is nothing like the one you show. As I stated it has to run through the exhaust pipes and fits fairly tight, so seems it has to have those molded corners.
kman.45
Re: Water Pump hose
Postby CasterTroy » Tue Feb 24, 2009 12:03 pm
Did you ever find hoses Kyle?
CasterTroy
Re: Water Pump hose
Postby nopantsflyer » Mon Mar 02, 2009 11:49 pm
i went to the local auto parts store and got all hoses replaced, had to get a T connector for the hoses on the left side, bought it there as well, had to shorten it on one side a little bit, should not be a problem replacing the hoses, michael
nopantsflyer
