Camshaft settings
Camshaft settings
Postby Jamie » Wed Apr 15, 2009 3:58 pm
Can anyone help,
with either the settings to re install the overhead cams,
or where i can find the service manual for a 2005 125 SM
:smt006
Jamie
Re: Camshaft settings
Postby djsbriscoe » Wed Apr 15, 2009 4:31 pm
The following MZ special tools are required to reinstall/set the camshafts. I've done this work myself and it's not too difficult a job.
It's also best if you put new gaskets on the chain tensioner and valve cover. It goes without saying that you'll need a torque wrench as well.
Crankshaft locking bolt 8999200000
Camshaft adjust tool 8999206000
All parts available from Grahams motorcycles in Taunton, Somerset (parts may take a while to arrive because of recent change in management at MZ in Germany)
Here is a zip file of the RT125 manual
MZ 125 RT Repair Manual OCR'd.zip
MZ RT125 Manual
(5 MiB) Downloaded 241 times
HTH,
David
Electronics tech by trade.
djsbriscoe
Postby Jamie » Thu Apr 16, 2009 3:13 pm
Thanks mate, that made things so much easier.
I wondered what the bolt was in the front of the engine, and now i know.
Managed without the special tools found a bolt long enough, and using a spanner on the cams, got over the other special tool.
Re assembled the engine only to find the starter relay was just clicking, so it may mean a trip to Grahams in Taunton.
Many thanks for your prompt reply.
Jamie
Jamie
Return to 125 cc
Users browsing this forum: No registered users and 64 guests
