Do-it-yourself - what do I need?
Postby RickBlaine » Fri Oct 06, 2006 10:37 pm
I want to start doing my own maintenance -- what tools and extra parts will I need, and where can I get them? Like, what air filters and other things, and are they available in the US?
RickBlaine
what bike
Postby DAVID THOMPSON » Sat Oct 07, 2006 9:26 am
what mz bikes do you own
oil filter for yamaha engines = kn-145
for mz 125cc and 500cc Rotax = kn151
the 151 is same as f650 bmw but not cheap
Postby RickBlaine » Sat Oct 07, 2006 11:16 am
oops -- 1995 Skorpion Tour
RickBlaine
tools
Postby DAVID THOMPSON » Sat Oct 07, 2006 6:33 pm
a copy of parts book page that shows the ori tools that came with bike
so that you can keep missing tools rounded up
:) tools are the only thing that can walk that do not have legs :)
the job is not done till all tools are back in tool bag or in there proper place
it is best to have a set you use in the shop and a set on the bike
what is left behind on the work bench is always the one you will need... :smt018
all sizes from small to 24mm but also check bike for large nuts and bolts
that are a size not in oem tool kit my saxon tour had a 18mm for rear wheel axel
but it was useless for the job and i include a breaker bar and 18mm socket with it as well as one for front axel not in the ori tool kit
the mz bikes i have use a lot of allen head bolts most bikes use philipps
so a set of allen that fit a socket wrench are a good start
and a small very good tourque wrench and use it
on my rt125 the right side engine case comes off for several adjustments
and a lot of service work will have you in a machine shop replacing the threads
in the main case if you get to hard on the allen wrench a few time tooo hard ....
the saying that feels about right only work for others when
there working on there own bike :)
also check and see if there are any easy to make special tools you may need for odd stuff
like my saxon tour has a rotax engine and the clutch cable if it needs to be replaced on the road there are not the right thing to get the job done
i made a special tool for the inside adjustment and a 2nd for the work bench there was stuff in the ori tool kit for the job but it was a pain to make work
do not use a crescent wrench it damages bolt heads ....Do use boxend or socket wrenchs......Vice Grips are the tool of a desperate man
any one out there have a copy of whats in the ori tool kit on a skorp tour post it i do not have that parts book
also check sparkplug wrench in bike kit and make sure it is right for plug
that is in the bike
in a tear down use a tray with compartments and store thing in the order they come apart.... this helps get it back in the right order ...i do this even
on engines i have been working on for years it marks the spot where you stopped working if you get interupted ...... :-D
Last edited by DAVID THOMPSON on Sun Oct 08, 2006 5:21 pm, edited 1 time in total.
Postby keithcross » Sun Oct 08, 2006 2:53 am
Besides the spare parts you need, get a good toolkit. Make it up yourself out of the sizes you need as if you buy sets you just end up paying for things you dont need.
The above, plus for roadside breakdowns, the standard tool kit and a membership card for a good recovery service :)
Re: Do-it-yourself - what do I need?
Postby billr » Thu Aug 06, 2009 7:27 pm
Old topic, but still useful. Especially since my Tour didn't come with the toolkit.
I wonder what people do with them???
I'll build one up using this as a guide.
I'd like to replace the factory tool-box with something like this:
Larger image here:
http://www.mzriders.com/gallery/menu.php?gallery=members&album_id=50
Mount it in the stock location, size to fit. (I wouldn't want this hanging off the back of the Skorp, bill)
It'll seal much better with the threaded cap.
If I can get it worked out, I'll post.
Anyone already done one and can send an example?
Bill
billr
Postby DAVID THOMPSON » Thu Aug 06, 2009 7:52 pm
look real close the tool box on my traveller was fastened to the bottom of the airbox right below the battery area
and very hard to see
i removed it as the door was screwed up
and the tools i got were in the saddlebag
yes i actually got some
i am thinking about hand making a small gas tank that fits there as one of the rides i go on
i run out of gas about 30 miles too soon
with planning maybe i can get 1 1/2 gallon there that i can pump in after i go about 100 miles
Postby billr » Fri Aug 07, 2009 5:15 am
The factory box is in place and empty.
The lid was loose, hanging by the "rivet" fastener.
I have the same type box on my enduro and it "seals" like a sieve, everything wet if not in baggies.
That gas tank idea is good.
You can get small electric or hand-cranked fuel pumps for RC engines.
They're small, light and would save searching for something to use as a pump.
Later,
Bill
billr
Postby DAVID THOMPSON » Fri Aug 07, 2009 9:07 am
thanks for the info on rc model pumps have not paid attention to rc planes of late
but sounds like a good source for a pump
i hate a service station stop on a trip costs 20 to 40 minutes and you can never make it up
Users browsing this forum: No registered users and 100 guests
